- From: Jean-Francois Monin <jean-francois.monin AT imag.fr>
- To: Daniel de Rauglaudre <daniel.de_rauglaudre AT inria.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] unblocked, thanks!
- Date: Mon, 13 Dec 2010 12:25:48 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=sender:date:from:to:cc:subject:message-id:references:mime-version :content-type:content-disposition:in-reply-to:user-agent; b=vTD5JzKtIwKyRMPqPYWvAvvhKvJIOC/ZbVzJyKiIGt4nOvPmMBcocO8IqBfZSQeaFX Hb3CCB+6mLr0AFgLiHr5InNQdPuqBs8tfB5WBj/pfPa4OlhcgztHSg9n9FnnTBvdTCXA KG9JKXLCuTXvHByB7fdI6AwEUkGDtHqmnHgwM=
Hi Daniel,
It is also a good opportunity to interpret this as a concrete
application of Curry-Howard. Making the induction over a quantified
formula is more than a trick, it is directly related to the kind of
(higher-order primitive) recursion used in the definition of sum -- a
pedantic way of presenting tail-recursion.
Conversely, you can make a very short "tail-recursive proof" of sum_S
as follows:
Lemma sum_S : forall a b : nat, sum a (S b) = S (sum a b).
Proof.
fix 2 (* better practice: use "refine", but I'm lazy *).
intros a [| b']; simpl.
reflexivity.
rewrite <- (sum_S (S a) b'). reflexivity.
Qed.
Cheers,
JF
On Mon, Dec 13, 2010 at 02:01:08AM +0100, Daniel de Rauglaudre wrote:
> Hi,
> On Sun, Dec 12, 2010 at 07:18:09PM +0100, Martijn Vermaat wrote:
> > I think the most obvious way is by first proving the following fact:
> Yeah! It works!
> I have my proof without "+", auto, nor importing modules.
> I learned many things. Thanks a lot!
> Fixpoint sum (a b : nat) : nat :=
> match b with
> | 0 => a
> | S b1 => sum (S a) b1
> end.
> Proof.
> intros a b; generalize a; generalize b; clear; induction b.
> reflexivity.
> intro a; simpl; rewrite <- (IHb (S a)); simpl; reflexivity.
> Qed.
> Lemma sum_zero : forall a : nat, sum 0 a = a.
> Proof.
> induction a.
> reflexivity.
> assert (H : (sum 0 (S a) = S (sum 0 a))) by apply sum_S.
> rewrite H; f_equal; assumption.
> Qed.
> http://pauillac.inria.fr/~ddr/
Jean-Francois Monin
CNRS-LIAMA, Project FORMES & Universite de Grenoble 1
Office 3-605, FIT, Tsinghua University
Haidian District, Beijing 100084, CHINA
Tel: +86 10 62 79 69 79 ext 605
Fax@LIAMA:
+86 10 6264 7458
- [Coq-Club] blocked in an elementary proof, Daniel de Rauglaudre
- Re: [Coq-Club] blocked in an elementary proof, Petar Maksimovic
Martijn Vermaat
- Re: [Coq-Club] blocked in an elementary proof, Stéphane Lescuyer
- Message not available
- Re: [Coq-Club] blocked in an elementary proof, Daniel de Rauglaudre
- Re: [Coq-Club] unblocked, thanks!,
- Re: [Coq-Club] unblocked, thanks!, Jean-Francois Monin
- Re: [Coq-Club] unblocked, thanks!, quentin . carbonneaux
- Re: [Coq-Club] unblocked, thanks!, AUGER Cedric
