- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] rewrite ... at ...
- Date: Tue, 8 Feb 2011 14:44:37 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:date:x-google-sender-auth:message-id:subject :from:to:content-type; b=XCgseoAVvqZ/00d635cqZRtYOqz1H9TLt6ZIjtz6wG43PPu6WfOeeqtnMvG42/0sQ7 yOs04rbI3eLH1tUkmUZgGQmafLp+pP/rkTICWml3FT2RA167yEqRd+JCgUTvvOFQri5B KQN22uYGyFWnj1Rx3qudvjygObya2Si6BUbeE=
Can someone explain the behavior below. There are clearly two
occurrences of lists eligible for rewriting. Which one is which? And
why does "at 2" fail?
- Aaron
Lemma foo:
forall (A: Type) (P: list A -> list A -> Prop) (x1 x2: A),
P (x1 :: nil) (x2 :: nil).
Proof.
intros *.
Goal is now:
If I execute:
rewrite <- List.app_nil_l.
Goal becomes:
P (x1 :: nil) (nil ++ x2 :: nil).
If I execute:
rewrite <- List.app_nil_l at 1.
Goal becomes:
P (nil ++ x1 :: nil) (x2 :: nil).
If I execute:
rewrite <- List.app_nil_l at 2.
Result is:
Tactic failure:setoid rewrite failed: no progress made.
- [Coq-Club] rewrite ... at ..., Aaron Bohannon
- Re: [Coq-Club] rewrite ... at ...,
Brandon Moore
Aaron Bohannon
Alexandre Pilkiewicz
Damien Pous
- Re: [Coq-Club] rewrite ... at ..., Matthieu Sozeau
Damien Pous
Aaron Bohannon
Brandon Moore
