- To: Brandon Moore <brandon_m_moore AT yahoo.com>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] rewrite ... at ...
- Date: Tue, 8 Feb 2011 20:00:22 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:cc:content-type; b=tx/mEvo0rQPc5Pqr2gK7sSEruZQ5J28t9M+lqZF6xkQZ2FqWJ9cV9Gb8qg2AoITjqG J4pN3iRkOISb8eTqKEwiJAaa/JmT11+RagZLkl3KaFC7HUPWDRHGLQDmKZBayYeBgKJv vZ2IJDSC19QBC4d3EhRxRIu2JQQl/5aSjgs80=
On Tue, Feb 8, 2011 at 5:54 PM, Brandon Moore
wrote:
> I just noticed arguments with underscores are allowed.
> "rewrite <- app_nil_l (x2::_)." will target the second instance.
> I think this would usually be almost as compact as using
> numbers, and much easier to read and write.
Ah, OK. Thanks for the partial explanation and this tip. I was
unfortunately in the situation where I have "P (e1 :: nil) (e2 ::
nil)" with e1 and e2 being very large expressions that are almost
identical except for deeply nested subterms. It seems that, without
out a clearly specified semantics for pattern positions, the most
succinct, non-fragile way to do the rewrite is something like this...
assert (H := forall l1 l2, P (nil ++ l1) l2 -> P l1 l2)
by (intros; replace l1 by (nil ++ l1) by app_nil_l; trivial).
apply H.
- Aaron
- [Coq-Club] rewrite ... at ..., Aaron Bohannon
- Re: [Coq-Club] rewrite ... at ...,
Brandon Moore
- Re: [Coq-Club] rewrite ... at ..., Aaron Bohannon
Alexandre Pilkiewicz
Damien Pous
- Re: [Coq-Club] rewrite ... at ..., Matthieu Sozeau
Damien Pous
Brandon Moore
