coq-club - Re: [Coq-Club] rewrite ... at ...
chronological Thread
  • From: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] rewrite ... at ...
  • Date: Wed, 9 Feb 2011 10:07:55 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=content-type:mime-version:subject:from:in-reply-to:date :content-transfer-encoding:message-id:references:to:x-mailer; b=m7Nim2PeeRtOEQCmSFbOZ4/MTIxdTn77JMh2oNNkS5Wx/ODDt/ecuw4mN1hbI0Xn4Z MWTCXw8HGTuBIIcy1NRjw5JoNzlVRMeMIkUNgZNiFSx56SQdKqfJMoURhSLy7h96QXGM yVZB9sa0BzO5wLH7xb7Q9QpPuTHOhf0KLWvFA=
Hi,
  indeed the semantics of [rewrite l at n] is to first
find a complete match [l'] of [l] and rewrite the [n]th instance
of [l'] in the goal whereas [setoid_rewrite l at n] will
rewrite the [n]th instance of [l], even allowing multiple rewrites
at once:
Lemma foo (A: Type) (P: list A -> list A -> Prop) (x1 x2: A):
P (x1 :: nil) (x2 :: nil).
Proof. intros. setoid_rewrite <- List.app_nil_l at 1 2.
Goal is : P (nil ++ x1 :: nil) (nil ++ x2 :: nil)
The fact that [rewrite l] first finds a single instance is for
backward compatibility reasons. The semantics of the positions
is clear though, there are 4 subterms of type [list A] here,
and they are found in left-to-right, top-down order. The only
tricky point here is that occurrences of an instance which are inside
a strict subterm of a rewritten occurrence are not taken into account,
hence the [2] in the above invocation applies to the [x2 :: nil] subterm
and not to the [nil] inside [x1 :: nil] because [x1 :: nil] itself
was rewritten.
Hope this helps,
-- Matthieu
Le 9 févr. 2011 à 09:10, Damien Pous a écrit :
> I recently filed a bug report about a similar behaviour with setoid
> relations:
> http://coq.inria.fr/bugs/show_bug.cgi?id=2474
> I didn't notice it was also problematic with plain Leibniz equality...
> Another option here is to use "setoid_rewrite at" rather than "rewrite
> at" (although "rewrite at" seems to be already implemented with
> setoids!):
> Require Import List.
> Proof.
> rewrite <- List.app_nil_l.
> Show Proof.                    (* eq_ind *)
> Restart.
> rewrite <- List.app_nil_l at 1.
> Show Proof.                    (* setoid things *)
> Restart.
> Fail rewrite <- List.app_nil_l at 2.
> setoid_rewrite <- List.app_nil_l at 2.
> Abort.
> Damien
