- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Problem with a simple fixpoint definition
- Date: Tue, 8 Feb 2011 22:38:07 -0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=from:to:subject:date:user-agent:mime-version:content-type :content-transfer-encoding:message-id; b=UaMN82noRVmCDb/NykoCMksldDICiTP4EibgTKasQPyzNi9p/QduSjK4MOjyzHiCZj 0t4pVHGjzxjDbEZAYlZ7O1eWyog1JnnD7VjIa1Dm81SCT3pzauqE01V0/vO1sIp3a1Vh SFEta4MJkVUJUj4/UlECliUsiPfd1rFew/KMo=
Here's my reduced version of the problem I'm seeing:
Parameter X:Type.
Parameter next:option X -> option X.
Inductive iteration_reaches_rel (x0:option X) :
option X -> option X -> Prop :=
| intro_iteration_reaches_rel: forall x:option X,
x <> x0 -> iteration_reaches_rel x0 (next x) x.
Definition iteration_reaches (x y:option X):Prop :=
Acc (iteration_reaches_rel y) x.
Notation "x ~~> y" := (iteration_reaches x y) (at level 100).
Lemma next_iteration_reaches: forall {x y:option X},
(x ~~> y) -> (x <> y) -> (next x ~~> y).
Proof.
intros.
destruct H.
apply H.
constructor.
assumption.
Defined. (* intentional, allows next definition to go through *)
Fixpoint iter_sub (x y:option X) (Hreach0 : x ~~> None) : option X.
refine (match x as x' return (x=x' -> option X) with
| Some x0 => fun _ =>
iter_sub (next x) (next y) (next_iteration_reaches Hreach0 _)
| None => fun _ => y
end (eq_refl _)).
rewrite _H; discriminate.
Defined.
Lemma iter_sub_None: forall (y:option X) (Hreach0 : None ~~> None),
iter_sub None y Hreach0 = y.
Proof.
intros.
reflexivity. (* fails *)
I don't see the problem here: it should be obvious that the match statement
goes to the None case and returns y. About the only unusual thing about the
fixpoint definition is that the match statement is on x instead of on the
decreasing parameter Hreach0 (which is broken down inside
next_iteration_reaches).
Daniel Schepler
- [Coq-Club] Problem with a simple fixpoint definition, Daniel Schepler
- Re: [Coq-Club] Problem with a simple fixpoint definition, Adam Chlipala
