- To: Daniel Schepler <dschepler AT gmail.com>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Problem with a simple fixpoint definition
- Date: Wed, 09 Feb 2011 08:03:18 -0500
Daniel Schepler wrote:
Fixpoint iter_sub (x y:option X) (Hreach0 : x ~~> None) : option X.
refine (match x as x' return (x=x' -> option X) with
| Some x0 => fun _ =>
iter_sub (next x) (next y) (next_iteration_reaches Hreach0 _)
| None => fun _ => y
end (eq_refl _)).
rewrite _H; discriminate.
Defined.
Lemma iter_sub_None: forall (y:option X) (Hreach0 : None ~~> None),
iter_sub None y Hreach0 = y.
Proof.
intros.
reflexivity. (* fails *)
I don't see the problem here: it should be obvious that the match statement
goes to the None case and returns y.
The beta reduction rule for [fix] terms only fires when the top-level structure of the recursive argument of the [fix] is known. In your example, the reduction you need is stuck on a [fix] whose recursive argument is the variable [Hreach0]. That's why no further progress can be made.
I found this problem quickly by running [compute] at the point where you wrote [reflexivity]. If you see what looks like a redex in the result of [compute], you know your assumptions about reduction need adjusting. :)
- [Coq-Club] Problem with a simple fixpoint definition, Daniel Schepler
- Re: [Coq-Club] Problem with a simple fixpoint definition, Adam Chlipala
