- To: Tom Prince <tom.prince AT ualberta.net>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Ltac automation.
- Date: Wed, 09 Feb 2011 19:20:58 -0500
Tom Prince wrote:
Inductive Term :=
| Var: nat → Term
| Op: Term → Term → Term.
Fixpoint eval_term {A: Type} (op: A → A → A) (var: nat → A) (t: Term) :=
match t with
| Var n => var n
| Op x y => op (eval_term op var x) (eval_term op var y)
end.
Inductive Equal := Eq: Term → Term → Equal.
Fixpoint eval_eq {A: Type} (op: A → A → A) (var: nat → A) (e: Equal) :=
let (x, y) := e in (eval_term op var x) = (eval_term op var y).
Inductive Laws : Equal -> Prop :=
| law_1 : Laws (Eq (Var 0) (Op (Var 0) (Var 1)))
| law_2 : Laws (Eq (Op (Var 0) (Var 0)) (Op (Var 1) (Var 0))).
Axiom (A: Type).
Axiom (op: A→A→A).
Axiom (laws_true: ∀ {E} (_: Laws E), ∀ x y, eval_eq op (fun n => match n with | 0
=> x | _ => y end) E).
Record rec (A: Type) (op: A→A→A) := { m1 : ∀ x y, x = (op x y) ; m2: ∀ x y,
(op x x) = (op y x) }.
Goal rec A op.
The following doesn't strike me as so bad:
Hint Extern 1 => apply (laws_true law_1) || apply (laws_true law_2).
Hint Constructors rec.
Goal rec A op.
auto.
Qed.
- [Coq-Club] Ltac automation., Tom Prince
- Re: [Coq-Club] Ltac automation.,
Adam Chlipala
Tom Prince
- Re: [Coq-Club] Ltac automation., Adam Chlipala
Tom Prince
Tom Prince
Tom Prince
- [Coq-Club] Re: Ltac automation.,
Tom Prince
- Re: [Coq-Club] Re: Ltac automation., gallais @ EnsL.org
- [Coq-Club] Re: Ltac automation., Tom Prince
Adam Chlipala
