- To: Adam Chlipala <adam AT chlipala.net>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Ltac automation.
- Date: Wed, 09 Feb 2011 18:42:06 -0500
On 2011-02-09, Adam Chlipala wrote:
> Tom Prince wrote:
> > Axiom param : nat -> Type.
> > Axiom val : ∀ n, param n.
> > [snip]
> > Record rec := { m1 : param 0; m7: param 6; m6: param 5 }.
> > Goal rec.
> I think the example is abstracted a bit too much to illustrate the
> issues, as [constructor; apply val] leads to the value of [rec] that
> you're looking for. Can you give a more complicated example which shows
> what makes your real code trickier?
This is much closer to the actual code I am using. The actual code deals
with multiple operations of different arities. And there are at least
half a dozen different types coresponding to Laws and rec, with differnt
collection of operations/laws. (Hence my desire to automate the proof.
Inductive Term :=
| Var: nat → Term
| Op: Term → Term → Term.
Fixpoint eval_term {A: Type} (op: A → A → A) (var: nat → A) (t: Term) :=
match t with
| Var n => var n
| Op x y => op (eval_term op var x) (eval_term op var y)
end.
Inductive Equal := Eq: Term → Term → Equal.
Fixpoint eval_eq {A: Type} (op: A → A → A) (var: nat → A) (e: Equal) :=
let (x, y) := e in (eval_term op var x) = (eval_term op var y).
Inductive Laws : Equal -> Prop :=
| law_1 : Laws (Eq (Var 0) (Op (Var 0) (Var 1)))
| law_2 : Laws (Eq (Op (Var 0) (Var 0)) (Op (Var 1) (Var 0))).
Axiom (A: Type).
Axiom (op: A→A→A).
Axiom (laws_true: ∀ {E} (_: Laws E), ∀ x y, eval_eq op (fun n => match n with
| 0 => x | _ => y end) E).
Record rec (A: Type) (op: A→A→A) := { m1 : ∀ x y, x = (op x y) ; m2: ∀ x y,
(op x x) = (op y x) }.
Goal rec A op.
constructor.
let n:= fresh in (evar (n:Equal); assert (Laws n) as P; subst n; [
constructor 1 | apply (laws_true P)]).
constructor 2 | apply (laws_true P)]).
Defined.
Goal rec A op.
Ltac TAC k := (let n:= fresh "n" in (evar (n:Equal); assert (Laws n) as P;
subst n); [ constructor k | apply (laws_true P) ]).
constructor; [TAC 1 | TAC 2].
- [Coq-Club] Ltac automation., Tom Prince
- Re: [Coq-Club] Ltac automation.,
Adam Chlipala
- Re: [Coq-Club] Ltac automation., Tom Prince
Adam Chlipala
Tom Prince
- Re: [Coq-Club] Ltac automation., Adam Chlipala
Tom Prince
Adam Chlipala
- [Coq-Club] Re: Ltac automation.,
Tom Prince
- Re: [Coq-Club] Re: Ltac automation., gallais @ EnsL.org
- [Coq-Club] Re: Ltac automation., Tom Prince
Adam Chlipala
