- To: Tom Prince <tom.prince AT ualberta.net>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Ltac automation.
- Date: Wed, 09 Feb 2011 21:11:36 -0500
Tom Prince wrote:
On 2011-02-10, Adam Chlipala wrote:
The following doesn't strike me as so bad:
Hint Extern 1 => apply (laws_true law_1) || apply (laws_true law_2).
Hint Constructors rec.
Goal rec A op.
auto.
Qed.
That certainly works. I was hoping to avoid having to mention the names
of all the constructors twice. If I am going to have to mention them
twice anyway, I might as well just apply them by hand.
That depends on the details of the theorems you want to prove. Already, with each law used just used, the proof script I've suggested avoids the need to include any kind of dependency on the order in which the inductive type constructors were declared (e.g., the constructor numbers you were trying to use in your original attempt). Also, if you prove multiple theorems that depend on the same facts, the same hint suffices to prove all of the theorems automatically.
- [Coq-Club] Ltac automation., Tom Prince
- Re: [Coq-Club] Ltac automation.,
Adam Chlipala
Tom Prince
Adam Chlipala
Tom Prince
- Re: [Coq-Club] Ltac automation., Adam Chlipala
Tom Prince
Adam Chlipala
Tom Prince
- [Coq-Club] Re: Ltac automation.,
Tom Prince
- Re: [Coq-Club] Re: Ltac automation., gallais @ EnsL.org
- [Coq-Club] Re: Ltac automation., Tom Prince
Adam Chlipala
