- From: St�phane Lescuyer <stephane.lescuyer AT inria.fr>
- To: Frederic Blanqui <frederic.blanqui AT inria.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Ascii module
- Date: Fri, 4 Mar 2011 10:30:04 +0100
Thank you for the references, this work of yours looks quite interesting
indeed.
Stéphane
On Thu, Mar 3, 2011 at 10:39 AM, Frederic Blanqui
wrote:
> You may be interested in knowing that, in the Formes team
> (http://formes.inria.fr/), we formalized in Coq a big part of the semantics
> of the ARMv6 processor. In fact, a big part of this formalization is
> generated automatically from the documentation. See
> http://www-rocq.inria.fr/~blanqui/rapido11-pdf.html for some details. A
> public release will certainly be done by the summer but I can provide some
> files if you are interested. We are also working on the processor SH4. Best
> regards, Frederic.
> Le 03/03/2011 16:32, Stéphane Lescuyer a écrit :
>> Incidentally, ARM processors were precisely the application I had in
>> mind when I inquired about hundreds of constructors. That's why I'm
>> curious about users who possibly tried that many constructors and
>> their experience with it.
>> S.
>> On Thu, Mar 3, 2011 at 4:16 AM, Frederic Blanqui
>>Â <frederic.blanqui AT inria.fr>
>> wrote:
>>> I don't think that this is so uncommon. For instance, processors often
>>> have
>>> dozens or hundreds of instructions. The ARMv6 processor has 147 32-bits
>>> instructions and 73 16-bits instructions... Many term rewrite systems in
>>> the
>>> Termination Problem Data Base have dozens of function symbols. Some have
>>> more than several hundred symbols. So, I would say that hundreds of
>>> constructors is not so uncommon. Now, thousands of constructors is
>>> perhaps
>>> more uncommon. Frederic.
I'm the kind of guy that until it happens, I won't worry about it. -
R.H. RoY05, MVP06
- [Coq-Club] Ascii module, AUGER Cedric
- Re: [Coq-Club] Ascii module,
Stéphane Lescuyer
AUGER Cedric
Frederic Blanqui
Stéphane Lescuyer
Frederic Blanqui
- Re: [Coq-Club] Ascii module, Stéphane Lescuyer
Frederic Blanqui
Stéphane Lescuyer
Frederic Blanqui
- Re: [Coq-Club] Ascii module, Brandon Moore
- Message not available
Stéphane Lescuyer
AUGER Cedric
Pierre Letouzey
- Re: [Coq-Club] Ascii module, Adam Koprowski
Pierre Letouzey
Stéphane Lescuyer
- Re: [Coq-Club] Ascii module, AUGER Cedric
Stéphane Lescuyer
AUGER Cedric
Stéphane Lescuyer
AUGER Cedric
Stéphane Lescuyer
