- From: St�phane Lescuyer <stephane.lescuyer AT inria.fr>
- To: Brandon Moore <brandon_m_moore AT yahoo.com>
- Cc: AUGER Cedric <Cedric.Auger AT lri.fr>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Ascii module
- Date: Fri, 4 Mar 2011 19:17:58 +0100
> How do you measure nodes in a term?
I wrote an ML plugin which measures proofs and definitions and keeps
track of statistics (it helps when trying out different design
decisions or comparing tactics, in order to see the impact it has on
proof size in particular). The size of a term is just the size of the
term in the internal AST representation.
> It is said that machine integers are used to implement reductions involving
> Numbers.Cyclic.Int31
> Would using that further reduce overhead?
I have never used native integers before, but it would possibly help
yes, although the overhead is so small that I'm not sure how much of
an improvement that would represent.
S.
I'm the kind of guy that until it happens, I won't worry about it. -
R.H. RoY05, MVP06
- Re: [Coq-Club] Ascii module, (continued)
- Re: [Coq-Club] Ascii module, Stéphane Lescuyer
- Re: [Coq-Club] Ascii module, Brandon Moore
- Message not available
Stéphane Lescuyer
AUGER Cedric
Pierre Letouzey
- Re: [Coq-Club] Ascii module, Adam Koprowski
Pierre Letouzey
Stéphane Lescuyer
- Re: [Coq-Club] Ascii module, AUGER Cedric
- Re: [Coq-Club] Ascii module, Tom Prince
Stéphane Lescuyer
AUGER Cedric
Stéphane Lescuyer
