- To: Pierre Letouzey <pierre.letouzey AT inria.fr>
- Cc: AUGER Cedric <Cedric.Auger AT lri.fr>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Ascii module
- Date: Fri, 4 Mar 2011 10:33:42 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :cc:content-type; b=jyt5haUVDD75HKXx3O4IZ0rWTZZ5N/0o3cOLA7+RTuVm6bemTFoB1HvYL8GuCW94jt H7ACY5A928ysXieAYMBLkAo8UgvZRrU59JlU88LnpfzDcAA2MaS7MR5GNoqMwWCv+azF VDzRHj+6TH59rhJLYCHBHwDkjDvs3u63SVX5E=
Dear all,
By the way, what about also reforming the module String someday ? I tend
to think that having an Haskell-like vision where string = list ascii
would be nicer than the current specialized pseudo-list type. This way,
many functions could be shared between String and List. Of course,
remain to be check that we could keep the specific parsing/printing
of strings even when string = list ascii...
If I may add my 5 cents: I used to work quite extensively with strings in Coq and indeed I found the specialized type for strings a nuisance, so the first thing I did was to re-define it as list of characters (for precisely the reason mentioned by Pierre: being able to use list functions for strings). So I give +1 to this idea :)
Best,
Adam
Adam Koprowski [http://adam-koprowski.net]
R&D @ MLstate [http://mlstate.com]
- Re: [Coq-Club] Ascii module, (continued)
Stéphane Lescuyer
AUGER Cedric
Frederic Blanqui
Stéphane Lescuyer
Frederic Blanqui
- Re: [Coq-Club] Ascii module, Stéphane Lescuyer
Frederic Blanqui
Stéphane Lescuyer
Frederic Blanqui
- Re: [Coq-Club] Ascii module, Brandon Moore
- Message not available
Stéphane Lescuyer
AUGER Cedric
Pierre Letouzey
- Re: [Coq-Club] Ascii module, Adam Koprowski
Pierre Letouzey
Stéphane Lescuyer
- Re: [Coq-Club] Ascii module, AUGER Cedric
- Re: [Coq-Club] Ascii module, Tom Prince
Stéphane Lescuyer
AUGER Cedric
Stéphane Lescuyer
AUGER Cedric
Stéphane Lescuyer
