- To: Daniel Schepler <dschepler AT gmail.com>
- Cc: coq-club AT inria.fr, David Baelde <david.baelde AT gmail.com>
- Subject: Re: [Coq-Club] Parametricity
- Date: Wed, 30 Mar 2011 13:43:43 -0400
Daniel Schepler wrote:
On Wednesday 30 March 2011 07:13:22 David Baelde wrote:
For example, any function of type (forall A:Type, A -> bool) must beNo, if you add
equal (at least extensively) to a constant function. It also seems
that there is no model of (subsets) of the CIC that doesn't force
parametricity. But do we know whether this is ruled out by the
calculus itself? In other words, can we prove from inside Coq that any
function of type (forall A:Type, A -> bool) is extensively equal to
some constant function?
Axiom classic_dec: forall P:Prop, {P} + {~P}.
then you can define
Definition inhabited_bool (A:Type) : bool :=
if classic_dec (inhabited A) then true else false.
Is this function really a counterexample? It doesn't include the argument of type [A] from the original question. That seems to play an important role; a function whose argument type is an unprovable proposition can certainly be considered to be "constant" at _any_ return value. In particular, it can be considered to be constant at [true]. The provable propositions naturally always lead to returning [true], too, with this version:
Definition inhabited_bool (A:Type) (_ : A) : bool :=
I can see how the frightening [classic_dec] function allows you to do very un-parametric things (and compute uncomputable functions!); I'm only questioning whether your example answers the original question.
Is [classic_dec] really consistent with CIC? It's not among the consistent axioms listed in the Coq FAQ. Maybe it falls out obviously from the standard boolean models; if so, that just leads me to distrust those models somehow. ;)
- [Coq-Club] Parametricity, David Baelde
- Re: [Coq-Club] Parametricity,
Daniel Schepler
- Re: [Coq-Club] Parametricity, Adam Chlipala
- Message not available
- Fwd: [Coq-Club] Parametricity, Daniel Schepler
Peter LeFanu Lumsdaine
- Re: [Coq-Club] Parametricity, David Baelde
Daniel Schepler
