- To: Coq Club <coq-club AT inria.fr>
- Subject: Fwd: [Coq-Club] Parametricity
- Date: Wed, 30 Mar 2011 12:30:14 -0700
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=cWzFTc2HDac/zqNvGR+EVj7r/GTQId89wEpAuvQuXelcflDo0vE0PN50iqR3SsZz93 pOElcQNQArM2mpWcGLz14SCKHGRVpJd4pp98FatZzPdGbgqed6iAHLCcTRKs6pfJlu/H 7BWnl4d18Ana2JMgSMibr81yQFT+emO9X5AZw=
Whoops, I accidentally sent this reply just to Adam instead of the whole list...
---------- Forwarded message ----------
Date: Wed, Mar 30, 2011 at 12:27 PM
Subject: Re: [Coq-Club] Parametricity
To: Adam Chlipala <adam AT chlipala.net>
Ah, sorry, I misread the desired type. Here's one using classic_dec which actually answers the question:
Require Import Classical.
Require Import Description.
Require Import Setoid.
Lemma classic_bool: forall P:Prop, {b:bool | if b then P else ~P}.
Proof.
intro P.
apply constructive_definite_description.
rewrite <- unique_existence.
split.
destruct (classic P).
exists true; trivial.
exists false; trivial.
intros [|] [|]; tauto.
Qed.
Definition classic_dec: forall P:Prop, {P} + {~P} :=
fun P => match (classic_bool P) with
| exist true p => left _ p
| exist false np => right _ np
end.
(* if A is bool, return the identity function, otherwise return the constant true function *)
Definition nonconst_on_bool: forall A:Type, A->bool :=
fun A => match (classic_dec ((bool:Type)=A)) with
| left p => match p in (_=T) return (T->bool) with
| eq_refl => fun b:bool => b
end
| right np => fun _ => true
end.
Lemma nonconst_on_bool_indeed_nonconst:
nonconst_on_bool bool true <> nonconst_on_bool bool false.
Proof.
intro e.
cut (forall b:bool, nonconst_on_bool bool b = b).
intro H.
congruence.
intro b.
unfold nonconst_on_bool.
destruct classic_dec.
replace e0 with (eq_refl (bool:Type)) by apply proof_irrelevance.
reflexivity.
contradiction n; reflexivity.
Qed.
Print Assumptions nonconst_on_bool_indeed_nonconst.
As for the question on consistency, the Print Assumptions returns just classic and constructive_definite_description. If the combination of those is inconsistent, which I highly doubt, then much of the work I've been doing reduces to triviality...
Daniel Schepler
On Wed, Mar 30, 2011 at 10:43 AM, Adam Chlipala <adam AT chlipala.net> wrote:
Daniel Schepler wrote:
On Wednesday 30 March 2011 07:13:22 David Baelde wrote:
No, if you addFor example, any function of type (forall A:Type, A -> bool) must be
equal (at least extensively) to a constant function. It also seems
that there is no model of (subsets) of the CIC that doesn't force
parametricity. But do we know whether this is ruled out by the
calculus itself? In other words, can we prove from inside Coq that any
function of type (forall A:Type, A -> bool) is extensively equal to
some constant function?
Axiom classic_dec: forall P:Prop, {P} + {~P}.
then you can define
Definition inhabited_bool (A:Type) : bool :=
if classic_dec (inhabited A) then true else false.
Is this function really a counterexample? It doesn't include the argument of type [A] from the original question. That seems to play an important role; a function whose argument type is an unprovable proposition can certainly be considered to be "constant" at _any_ return value. In particular, it can be considered to be constant at [true]. The provable propositions naturally always lead to returning [true], too, with this version:
Proof.
intro P.
split.
Qed.
end.
end
end.
Proof.
intro e.
intro H.
congruence.
intro b.
reflexivity.
Qed.
Daniel Schepler
- [Coq-Club] Parametricity, David Baelde
- Re: [Coq-Club] Parametricity,
Daniel Schepler
Adam Chlipala
- Message not available
- Fwd: [Coq-Club] Parametricity, Daniel Schepler
Peter LeFanu Lumsdaine
- Re: [Coq-Club] Parametricity, David Baelde
Adam Chlipala
Daniel Schepler
