- To: Pierre Casteran <pierre.casteran AT labri.fr>, Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Problem with a simple proof
- Date: Thu, 7 Apr 2011 22:33:37 +0900
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:from:date :x-google-sender-auth:message-id:subject:to:content-type; b=dB+IHznOJvSv1D/5+3Z6vsUYvHTbgh8qBl+IeJQWnRyojrjoKL4rMyaVjFr954si/s yA3OpsCNK8WJBvXrEuwusjmQIuXaRoutpN5KYrI/tAZTGQ13vCLGaTHdEbU9pSkuKGBS bEeYMJCoun2yDNC/NpXpLcmc76nh/8+MZbc4Y=
Dear all,
First, thank you so much, Pierre Casteran.
I have one more question about a proof.
How can I solve such proof when I cannot use Peano_dec.
For example, In this case, I think I cannot prove
Lemma sub_ty_same_or_not: forall t1 t2, (sub_ty t1 t2) \/ ~(sub_ty t1 t2).
Therefore, I cannot use the same approach for Lemma subtyset_ex
Is there any way to prove Lemma subtyset_ex?
Or, Do I have to change subtyset definition?
Thanks.
Definition ty := nat.
Notation tytable := (list (ty * ty)).Parameter TT : tytable.Definition extends (t1: ty) (t2: ty) : Prop :=In (t1, t2) TT.Inductive sub_ty : ty -> ty -> Prop :=| sub_refl : forall t, sub_ty t t| sub_trans : forall t1 t2 t3, sub_ty t1 t2 -> sub_ty t2 t3 -> sub_ty t1 t3| sub_tapp : forall t1 t2, extends t1 t2 -> sub_ty t1 t2.Inductive subtyset : ty -> list ty -> list ty -> Prop :=| subtysetnil : forall t, subtyset t nil nil| subtysetnoadd: forall t t' ts1 ts2,subtyset t ts1 ts2 ->~(sub_ty t' t) ->subtyset t (t'::ts1) ts2| subtysetadd: forall t t' ts1 ts2,subtyset t ts1 ts2 ->sub_ty t' t ->subtyset t (t'::ts1) (t'::ts2).Lemma subtyset_ex: forall t ts1,exists ts2, subtyset t ts1 ts2.Proof.induction ts1.exists nil. constructor 1.destruct IHts1 as (ts2, H)........
2011/4/7 Pierre Casteran <pierre.casteran AT labri.fr>
Dear Jieung Kim,
You can proceed to an induction on l1', which is used to build l2' step by step.
Require Import Peano_dec.induction l1'; simpl.
Lemma LC_subset: forall n l1 l2 l1',
LessCollection n l1 l2 ->
exists l2', LessCollection n (l1'++l1) (l2'++l2).
Proof.
exists nil;simpl;auto.
intro H; destruct (IHl1' H) as [l2' H2]; case (Lt.le_or_lt n a).
intro H3;exists (a::l2');constructor 3;simpl;auto.
intro H3;exists l2';constructor 2;simpl;auto with arith.
Qed.
In fact, you can use the same kind of argument to prove also the simpler lemma:
Lemma LesCollection_ex : forall n l1, exists l2, LessCollection n l1 l2.
The best,
Pierre
Le 07/04/2011 08:49, Jieung Kim a écrit :Dear all,
I'm trying to prove the Lemma LC_subset, and I tried to do an induction on list l1.However, I cannot find a way to prove second subgoal and think additional lemma to prove it.
Could you tell me the way to prove such a lemma?
Thanks.
Require Import List.
Inductive LessCollection: nat -> list nat -> list nat -> Prop :=| LCnil: forall n, LessCollection n nil nil| LCnoadd: forall n l1 l2 n',LessCollection n l1 l2 ->~(le n n') ->LessCollection n (n'::l1) l2| LCadd: forall n l1 l2 n',LessCollection n l1 l2 ->le n n' ->LessCollection n (n'::l1) (n'::l2).
Lemma LC_subset: forall n l1 l2 l1',LessCollection n l1 l2 ->exists l2', LessCollection n (l1'++l1) (l2'++l2).Proof.--
Jieung Kim ( 김지응 )
Programming Language Research Group, KAIST
E-mail : gbali at kaist.ac.kr
je1004k at gmail.com
Homepage : plrg.kaist.ac.kr/kje
Jieung Kim ( 김지응 )
- [Coq-Club] Problem with a simple proof, Jieung Kim
- Re: [Coq-Club] Problem with a simple proof,
Pierre Casteran
- Re: [Coq-Club] Problem with a simple proof, Jieung Kim
Adam Chlipala
Pierre Casteran
Adam Chlipala
Pierre Casteran
