coq-club - Re: [Coq-Club] Guard Condition
chronological Thread
  • To: Georges Gonthier <gonthier AT microsoft.com>, Coq-Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Guard Condition
  • Date: Fri, 08 Apr 2011 20:38:26 +0200
I'm curious:  When did the "structurally" recursive version
of mod appearing below first appear?
Gert
Am 08.04.2011 19:14, schrieb Georges Gonthier:
   This behavior is actually covered by [2], which defines two notions:
"structurally smaller than" and "structurally smaller than or equal to".
   minus x y, as defined in the ssr library, is "structurally smaller than or
equal to" x,
because x is the structural argument of minus, and all match branches return
either x or a proper recursive call to minus. This is not the case for
minus', as 0 is syntactically unrelated to x (even though it is provably
equal to x in that branch!).
Georges
-----Original Message-----
[mailto:doczkal AT ps.uni-saarland.de]
Sent: 08 April 2011 17:22
To: Coq-Club
Subject: [Coq-Club] Guard Condition
Dear Coq-Club.
The guard condition for "fix" appears to be under active
development [1]. I would be interested in the exact guard condition
implemented in Coq 8.3.
Is there any document (besides the Coq sources) where the details of the
guard condition are explained? The Coq manual refers to [2], but this
seems to be only part of what is implemented.
The particular example I found rather stunning is the recursive version
of mod (ported from the Ssreflect libraries).
Fixpoint minus (x y : nat) : nat :=
   match x, y with
     | _, O =>  x
     | O, _ =>  x
     | S x', S y' =>  minus x' y'
   end.
Fixpoint mod' x y {struct x} :=
   match minus x y  with
     | O =>  x
     | S x' =>  mod' x' y
   end.
Definition mod  (x y : nat) : nat := mod' x (minus y (S O)).
I would be happy if someone could explain why mod' is accepted (It seems
to not be covered by [2]). Furthermore, I would like to understand why
the above definition of mod' is not accepted if we replace minus by the
following semantically equivalent version:
   match x, y with
     | _, O =>  x
     | O, _ =>  O (* x changed to O *)
   end.
Thanks in advance.
Regards
Christian
[1] Pierre Boutillier, Subject: Re: [Coq-Club] Destruct vs. inversion
https://sympa-roc.inria.fr/wws/arc/coq-club/2011-04/msg00027.html
[2] E. Gimenez "Codifying guarded definitions with recursive schemes"
