- To: Gert Smolka <smolka AT ps.uni-saarland.de>, Coq-Club <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] Guard Condition
- Date: Fri, 8 Apr 2011 19:38:43 +0000
- Accept-language: en-GB, en-US
It was committed in the ssreflect library archive on February 14, 2008; my
previous commit was on February 4, so it appeared somewhere in between. I
coined it independently, which is not to say someone hadn't come up with it
before.
Georges
-----Original Message-----
[mailto:smolka AT ps.uni-saarland.de]
Sent: 08 April 2011 19:38
To: Georges Gonthier; Coq-Club
Subject: Re: [Coq-Club] Guard Condition
I'm curious: When did the "structurally" recursive version
of mod appearing below first appear?
Gert
Am 08.04.2011 19:14, schrieb Georges Gonthier:
> This behavior is actually covered by [2], which defines two notions:
> "structurally smaller than" and "structurally smaller than or equal to".
> minus x y, as defined in the ssr library, is "structurally smaller than
> or equal to" x,
> because x is the structural argument of minus, and all match branches
> return either x or a proper recursive call to minus. This is not the case
> for minus', as 0 is syntactically unrelated to x (even though it is
> provably equal to x in that branch!).
> Georges
> From: Christian Doczkal
> [mailto:doczkal AT ps.uni-saarland.de]
> Sent: 08 April 2011 17:22
> To: Coq-Club
> Subject: [Coq-Club] Guard Condition
> Dear Coq-Club.
> The guard condition for "fix" appears to be under active
> development [1]. I would be interested in the exact guard condition
> implemented in Coq 8.3.
> Is there any document (besides the Coq sources) where the details of the
> guard condition are explained? The Coq manual refers to [2], but this
> seems to be only part of what is implemented.
> The particular example I found rather stunning is the recursive version
> of mod (ported from the Ssreflect libraries).
> Fixpoint minus (x y : nat) : nat :=
> match x, y with
> | _, O => x
> | O, _ => x
> | S x', S y' => minus x' y'
> end.
> Fixpoint mod' x y {struct x} :=
> match minus x y with
> | O => x
> | S x' => mod' x' y
> end.
> Definition mod (x y : nat) : nat := mod' x (minus y (S O)).
> I would be happy if someone could explain why mod' is accepted (It seems
> to not be covered by [2]). Furthermore, I would like to understand why
> the above definition of mod' is not accepted if we replace minus by the
> following semantically equivalent version:
> match x, y with
> | _, O => x
> | O, _ => O (* x changed to O *)
> end.
> Thanks in advance.
> Regards
> Christian
> [1] Pierre Boutillier, Subject: Re: [Coq-Club] Destruct vs. inversion
> https://sympa-roc.inria.fr/wws/arc/coq-club/2011-04/msg00027.html
> [2] E. Gimenez "Codifying guarded definitions with recursive schemes"
- [Coq-Club] Guard Condition, Christian Doczkal
- RE: [Coq-Club] Guard Condition,
Georges Gonthier
- Re: [Coq-Club] Guard Condition,
Gert Smolka
- RE: [Coq-Club] Guard Condition, Georges Gonthier
- [Coq-Club] Impredicative [ Set ],
Vladimir Voevodsky
- Re: [Coq-Club] Impredicative [ Set ],
Gregory Malecha
- Message not available
- Re: [Coq-Club] Impredicative [ Set ], Vladimir Voevodsky
- Re: [Coq-Club] Impredicative [ Set ], Gregory Malecha
- Re: [Coq-Club] Impredicative [ Set ], Pierre Courtieu
- [Coq-Club] messy behavior with universes, Vladimir Voevodsky
- [Coq-Club] Re: [coqdev] messy behavior with universes, Tom Prince
- [Coq-Club] Re: [coqdev] messy behavior with universes, Vladimir Voevodsky
- Re: [Coq-Club] Re: [coqdev] messy behavior with universes, Carlos Simpson
Gregory Malecha
Vladimir Voevodsky
Gert Smolka
Georges Gonthier
