- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Re: [coqdev] messy behavior with universes
- Date: Mon, 18 Apr 2011 19:24:13 +0200
On Mon, Apr 18, 2011 at 11:41:13AM -0400, Randy Pollack wrote:
> Matita (from Bologna) has some kind of explicit universe notation.
And this is the most up-to-date description of them (pages 2 and 3):
http://matita.cs.unibo.it/docs/tutorial/igft.pdf
We were also pondering on quantifiers (as proposed earlier on this list) but
we never tried to prototype them, nor study their theory.
The closest thing that was (partially) implemented was a command to
duplicate CIC objects applying to them a sort-substitution (without
manually duplicating .v files of course).
Cheers
Enrico Tassi
- Re: [Coq-Club] Impredicative [ Set ], (continued)
Gregory Malecha
- Message not available
- Re: [Coq-Club] Impredicative [ Set ], Vladimir Voevodsky
- Re: [Coq-Club] Impredicative [ Set ], Gregory Malecha
- Re: [Coq-Club] Impredicative [ Set ], Pierre Courtieu
- [Coq-Club] messy behavior with universes, Vladimir Voevodsky
- [Coq-Club] Re: [coqdev] messy behavior with universes, Tom Prince
- [Coq-Club] Re: [coqdev] messy behavior with universes, Vladimir Voevodsky
- Re: [Coq-Club] Re: [coqdev] messy behavior with universes, Carlos Simpson
- Re: [Coq-Club] Re: [coqdev] messy behavior with universes, Vladimir Voevodsky
- Re: [Coq-Club] Re: [coqdev] messy behavior with universes, Enrico Tassi
Gregory Malecha
- Re: [Coq-Club] Re: [coqdev] messy behavior with universes, Andreas Abel
- [Coq-Club] THedu'11 at CADE: last call for ext.abstracts, Laurent Théry
- [Coq-Club] an issue with notations, Vladimir Voevodsky
- [Coq-Club] a problem with canonical structures, Vladimir Voevodsky
- Re: [Coq-Club] a problem with canonical structures, Cyril Cohen
- [Coq-Club] Another question, Vladimir Voevodsky
- Re: [Coq-Club] Another question, Vincent Siles
- Re: [Coq-Club] an issue with notations, Hugo Herbelin
- Re: [Coq-Club] an issue with notations, Vladimir Voevodsky
- Re: [Coq-Club] an issue with notations, Tom Prince
