- To: Randy Pollack <rpollack AT inf.ed.ac.uk>
- Cc: Vladimir Voevodsky <vladimir AT ias.edu>, Carlos Simpson <Carlos.Simpson AT unice.fr>, Tom Prince <tom.prince AT ualberta.net>, Coq-Club Club <coq-club AT inria.fr>, coqdev <coqdev AT inria.fr>
- Subject: Re: [Coq-Club] Re: [coqdev] messy behavior with universes
- Date: Tue, 19 Apr 2011 08:14:50 +0200
On 18.04.11 5:41 PM, Randy Pollack wrote:
Agda has some nearly-first-class treatment of universe levels. I
don't know what the theory behind it is.
We are working on it... ;-) The theory should become clearer in the near future.
Cheers,
Andreas
Matita (from Bologna) has some kind of explicit universe notation.
Look at the very old paper by Robert Harper and myself: "Type
checking with universes" Theoretical Computer Science, 89:107-136,
1991 (file attached), where we give a detailed account of typical
ambiguity and type polymorphism (not the same thing) in a slightly
simpler system than the current CIC.
Randy
On Mon, Apr 18, 2011 at 9:51 AM, Vladimir
Voevodsky<vladimir AT ias.edu>
wrote:
Dear Carlos,
there is no need to introduce a new universe every time "Type" is mentioned.
At the beginning of the file one declares the universe structure which one wants to
work with by something like
Variable UU0 UU1 : Univ.
etc.
(of course currently there is no identifier Univ and also Univ is not a type.
May be one should use something other than : with Univ.)
Then one can have a definition like that:
Definition iscontr {U:Univ}(T:U) : U := ....
which is polymorphic or like that
Definition trrr (T:UU0):UU0 :=
which assumes a fixed universe UU0.
Vladimir.
On Apr 16, 2011, at 10:26 AM, Carlos Simpson wrote:
Dear Vladimir,
It may be an interesting theoretical question to try to understand
what happens if we try to make all definitions parametric over universes.
Of course each time you make a new definition this introduces possibly many
new universe indices. It could have something to do with quantum mechanics
in that the ``universes'' which occur here might be related to the
``universes'' in the many-universe interpretation of quantum mechanics.
---Carlos Simpson
Selon Vladimir
Voevodsky<vladimir AT ias.edu>:
Uhhh-uhh. I see. I got so used working with fixed universes that I forgot
about this behavior. Thanks! V.
On Apr 15, 2011, at 7:24 PM, Tom Prince wrote:
On 2011-04-15, Vladimir Voevodsky wrote:is in Set. This does not look right.
In the following example:
File 1 (ex1.v) :
Definition dneg (X:Type) := ((X -> Empty_set) -> Empty_set).
File 2 (ex2.v):
Require Export ex1.
Variable X:Set.
Check (dneg X).
Check ((X -> Empty_set)-> Empty_set).
Coq responds that (dneg X) is in Type while ((X -> Empty_set)-> Empty_set)
This is expected. Everything in Set is also in type, so
Check ((X -> Empty_set)-> Empty_set) : Type.
Unfortunately, coq doesn't currently support looking through the
definition of dneg to see that (dneg X) is convertible with a term of
sort Set.
There is limited support for doing this with paramaters of inductives,
but nothing else.
Tom
Andreas Abel <>< Du bist der geliebte Mensch.
Theoretical Computer Science, University of Munich
Oettingenstr. 67, D-80538 Munich, GERMANY
andreas.abel AT ifi.lmu.de
http://www2.tcs.ifi.lmu.de/~abel/
- Re: [Coq-Club] Impredicative [ Set ], (continued)
- Message not available
- Re: [Coq-Club] Impredicative [ Set ], Vladimir Voevodsky
- Re: [Coq-Club] Impredicative [ Set ], Gregory Malecha
- Re: [Coq-Club] Impredicative [ Set ], Pierre Courtieu
- [Coq-Club] messy behavior with universes, Vladimir Voevodsky
- [Coq-Club] Re: [coqdev] messy behavior with universes, Tom Prince
- [Coq-Club] Re: [coqdev] messy behavior with universes, Vladimir Voevodsky
- Re: [Coq-Club] Re: [coqdev] messy behavior with universes, Carlos Simpson
- Re: [Coq-Club] Re: [coqdev] messy behavior with universes, Vladimir Voevodsky
- Re: [Coq-Club] Re: [coqdev] messy behavior with universes, Enrico Tassi
- Re: [Coq-Club] Re: [coqdev] messy behavior with universes, Andreas Abel
- [Coq-Club] THedu'11 at CADE: last call for ext.abstracts, Laurent Théry
- [Coq-Club] an issue with notations, Vladimir Voevodsky
- [Coq-Club] a problem with canonical structures, Vladimir Voevodsky
- Re: [Coq-Club] a problem with canonical structures, Cyril Cohen
- [Coq-Club] Another question, Vladimir Voevodsky
- Re: [Coq-Club] Another question, Vincent Siles
- Re: [Coq-Club] an issue with notations, Hugo Herbelin
- Re: [Coq-Club] an issue with notations, Vladimir Voevodsky
- Re: [Coq-Club] an issue with notations, Tom Prince
- Re: [Coq-Club] Impredicative [ Set ], Alexandre Pilkiewicz
