coq-club - Re: [Coq-Club] Breaking typeclass instance cycles
chronological Thread
  • To: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
  • Cc: Daniel Schepler <dschepler AT gmail.com>, Robbert Krebbers <mail AT robbertkrebbers.nl>, Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Breaking typeclass instance cycles
  • Date: Sat, 07 May 2011 01:04:18 -0400
On 2011-05-06, Matthieu Sozeau wrote:
> > Class Arrows (O: Type): Type := Arrow: O → O → Type.
> > Instance flipA {Object} {A: Arrows Object}: Arrows Object := flip A.
> > CoInductive dual_arrows_done (T: Type) : Prop := did_dual_arrows.
> > Hint Extern 100 (Arrows ?x) => match goal with
> >                                 | _ : dual_arrows_done x |- _ => fail 1
> >                                 | |- _ => let H:=fresh "H" in set
> > (H:=did_dual_arrows x); class_apply @flipA
> >                               end : typeclass_instances.
>   There is no way to tell if a flipA should be triggerd here, is there?
> If you had a dummy [flipObject] definition to act as an index you could
> control its application using an [Arrows (flipObject ?x)] pattern, but
> I guess you don't want that.
Well, I am not sure I have all the permutations, but I think I can
describe when it should be applied.
1) If we have already tried to apply other instances
*and*
2) We are not deducing the argument of flipA. (in particular, when the
outer flipA is provided by the user, not deduced.
It is a subtle thing, though, since adding the above hint also leads to
cycles caused by the instances defined in terms of flipA, that I haven't
figured out yet.
  Tom
