- From: frank maltman <frank.maltman AT googlemail.com>
- To: Adam Chlipala <adam AT chlipala.net>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Length indexed vector 'index'
- Date: Mon, 16 May 2011 05:12:49 +0000
- Domainkey-signature: a=rsa-sha1; c=nofws; d=googlemail.com; s=gamma; h=date:from:to:cc:subject:message-id:in-reply-to:references:x-mailer :mime-version:content-type:content-transfer-encoding; b=Kxev8u3oEdXS64ntr12nlgZcNIWUL1qzE38duW2+qB6pcIQDDlPVkFumqyAs2n43hs WkPabIjWQo2amhfjTZXr+v+MiGlcKFdUN8UCsTwIVkq9CM2Ot8DwiLrglPfA14q3KMi5 7ERriLTcrszXXL8pYzsOpcZjqxuE0ygtCbxPg=
On Sun, 15 May 2011 09:43:04 -0400
Adam Chlipala
wrote:
> I just want to make sure you're aware that all of these definitions
> (including the one you're struggling with) also appear in "Certified
> Programming with Dependent Types."
I've just applied the techniques given in the 'Dependent Data Structures'
chapter and have come across something rather nasty.
This:
Fixpoint index {A : Type} {b : nat} (v : vector A b) : F.finite b -> A :=
match v with
| VZ =>
fun i =>
match i in (F.finite b') return (match b' with | 0 => A | S _ => unit
end) with
| F.FO _ => tt
| F.FS _ _ => tt
end
| VC _ x xs =>
fun i =>
match i in (F.finite b') return ((F.finite (pred b') -> A) -> A) with
| F.FO _ => fun _ => x
| F.FS _ f' => fun index' => index' f'
end (index xs)
end.
... typechecks.
This:
match v with
| VZ =>
(fun i =>
end) with
| F.FO _ => tt
| F.FS _ _ => tt
end)
| VC _ x xs =>
(fun i =>
end) (index xs)
end.
Gives the following incomprehensible error:
Error:
In environment
index : forall (A : Type) (b : nat), vector A b -> F.finite b -> A
A : Type
b : nat
v : vector A b
i : F.finite ?41
The term
"match
i in (F.finite b') return match b' with
| 0 => A
| S _ => unit
end
with
| F.FO _ => tt
| F.FS _ _ => tt
end" has type "match ?41 with
| 0 => A
| S _ => unit
end" while it is expected to have type
"A".
I assume this is down to the various heuristics used to infer types?
I'm at a bit of a loss as to how the addition of a pair of parentheses
could do so much damage!
- [Coq-Club] Length indexed vector 'index', frank maltman
- Re: [Coq-Club] Length indexed vector 'index',
Adam Chlipala
frank maltman
- Message not available
- Re: [Coq-Club] Length indexed vector 'index', frank maltman
- Re: [Coq-Club] Length indexed vector 'index', Matthieu Sozeau
Brandon Moore
frank maltman
Adam Chlipala
Adam Chlipala
frank maltman
Adam Chlipala
