coq-club - Re: [Coq-Club] Length indexed vector 'index'
chronological Thread
  • To: frank maltman <frank.maltman AT googlemail.com>, Adam Chlipala <adam AT chlipala.net>
  • Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Length indexed vector 'index'
  • Date: Mon, 16 May 2011 12:52:12 -0700 (PDT)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Message-ID:X-YMail-OSG:Received:X-Mailer:References:Date:From:Reply-To:Subject:To:Cc:In-Reply-To:MIME-Version:Content-Type:Content-Transfer-Encoding; b=WpzKyH/tF8JT9a7MLn63D8b14h9JXiLh1ZBmKDN1GBGeJea+9n4juV+C7ehGmnatahRZo19O5G2P4ECUapu+/U3fptc+F2D402H8OgoNDFcUbXewl92K8S1tjOPCvMTIsZscyuH5iffqK/KwERaHRLC4EQiM1pVaDOr6fulV6RA=;
> From: frank maltman
> Sent: Monday, May 16, 2011 12:12 AM
> On Sun, 15 May 2011 09:43:04 -0400
> Adam Chlipala
>  wrote:
>>  I just want to make sure you're aware that all of these definitions
>>  (including the one you're struggling with) also appear in
> "Certified
>>  Programming with Dependent Types."
> I've just applied the techniques given in the 'Dependent Data
> Structures'
> chapter and have come across something rather nasty.
> This:
> Fixpoint index {A : Type} {b : nat} (v : vector A b) : F.finite b -> A :=
>   match v with
>     | VZ =>
>       fun i =>
>         match i in (F.finite b') return (match b' with | 0 => A | S _
> => unit end) with
>           | F.FO _   => tt
>           | F.FS _ _ => tt
>         end
>     | VC _ x xs =>
>       fun i =>
>         match i in (F.finite b') return ((F.finite (pred b') -> A)
> -> A) with
>           | F.FO _    => fun _      => x
>           | F.FS _ f' => fun index' => index' f'
>         end (index xs)
>   end.
> ... typechecks.
> This:
>   match v with
>     | VZ =>
>       (fun i =>
> => unit end) with
>           | F.FO _   => tt
>           | F.FS _ _ => tt
>         end)
>     | VC _ x xs =>
>       (fun i =>
> -> A) with
>         end) (index xs)
>   end.
> Gives the following incomprehensible error:
> Error:
> In environment
> index : forall (A : Type) (b : nat), vector A b -> F.finite b -> A
> A : Type
> b : nat
> v : vector A b
> i : F.finite ?41
> The term
> "match
>     i in (F.finite b') return match b' with
>                               | 0 => A
>                               | S _ => unit
>                               end
>   with
>   | F.FO _ => tt
>   | F.FS _ _ => tt
>   end" has type "match ?41 with
>                  | 0 => A
>                  | S _ => unit
>                  end" while it is expected to have type
> "A".
> I assume this is down to the various heuristics used to infer types?
> I'm at a bit of a loss as to how the addition of a pair of parentheses
> could do so much damage!
It might be a little more comprehensible if you write it out with more
parentheses.
You turn
>       fun i =>
>         ((match i in (F.finite b') return ((F.finite (pred b') -> A)
> -> A) with
>         end) (index xs))
into
>       (fun i =>
> -> A) with
>         end)) (index xs)
I hope it's less surprising that (fun x => (E g))
can be rather different from (fun x => E), which is E[g/x]
Brandon
