coq-club - Re: [Coq-Club] Length indexed vector 'index'
chronological Thread
  • From: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
  • To: frank maltman <frank.maltman AT googlemail.com>
  • Cc: Adam Chlipala <adam AT chlipala.net>, coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Length indexed vector 'index'
  • Date: Mon, 16 May 2011 09:03:22 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=subject:mime-version:content-type:from:in-reply-to:date:cc :content-transfer-encoding:message-id:references:to:x-mailer; b=mtisIbpkr6L+659p8qy55tzw+FHCEq5U568eRiFbxb638XxsFhxImOgsZfeO+oVaJQ +M40V+UYameoktSPyBofzFuGw9dysNECmAGD3etam8pY1DfKzDUNbn0d6WoV1B1kM0Hh 2z2+5rQ43oQhWGkZhkrw0NoiWrQHAXx15hrRI=
Hello Frank,
Le 16 mai 2011 à 07:12, frank maltman a écrit :
> On Sun, 15 May 2011 09:43:04 -0400
> Adam Chlipala
>  wrote:
>> I just want to make sure you're aware that all of these definitions
>> (including the one you're struggling with) also appear in "Certified
>> Programming with Dependent Types."
<snip/>
>    | VC _ x xs =>
>      (fun i =>
>        match i in (F.finite b') return ((F.finite (pred b') -> A) -> A) with
>          | F.FO _    => fun _      => x
>          | F.FS _ f' => fun index' => index' f'
>        end) (index xs)
>  end.
This application of (fun i => ...) to (index xs) is ill-typed, the first
parenthesis
should be around the match. Indeed the error message is not the one you
expect due to heuristics in the type-checking of pattern-matching.
> Gives the following incomprehensible error:
> Error:
> In environment
> index : forall (A : Type) (b : nat), vector A b -> F.finite b -> A
> A : Type
> b : nat
> v : vector A b
> i : F.finite ?41
> The term
> "match
>    i in (F.finite b') return match b' with
>                              | 0 => A
>                              | S _ => unit
>                              end
>  with
>  | F.FO _ => tt
>  | F.FS _ _ => tt
>  end" has type "match ?41 with
>                 | 0 => A
>                 | S _ => unit
>                 end" while it is expected to have type
> "A".
> I assume this is down to the various heuristics used to infer types?
> I'm at a bit of a loss as to how the addition of a pair of parentheses
> could do so much damage!
