- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] how a client should check a Coq proof for cheating?
- Date: Mon, 16 May 2011 17:43:49 +0200
> please excuse my dumbness, i am new to Coq.
> i am trying to convince a client a bit counterintuitive proof is valid.
> it is my understanding there must be no axioms (coqchk -o) and in coqtop
> "Print lemma_X." should print after ":" the statement of the .v source file.
You could also use Check lemma_X to avoid printing the proof term you
probably don't want to see at that point, since you've already checked
out for the axioms used.
> should the client do other checks in the example below?
If I were the client I would disable all customized notations with
Unset Printing All.
Then I would do Print on all the definitions involved directly or
indirectly in the type of lemma_X, to check they are what they're
supposed to be. It remains to see that symbols like -> forall match etc.
are not fake (see below).
> should i take any action to improve the example? (if it happens
> valid/invalid i suppose i can change it a lot...):
> (* coqtop is not fiddled by me, no east european plugins. coqchk -o passed
> genuinely and showed no axioms.).
> fuck_m$>coqtop
> Welcome to Coq 8.2pl1 (February 2010)
> Coq < Require Import fib10.
> Coq < Print c1.
> c1 = SOME_STUF ending in ')\n'
> : True -> forall x : Prop, True -> x
> Coq < Lemma l1: True -> forall x : Prop, True -> x.
> l1 < apply c1.
> Proof completed.
Here I would try to do
Check (@c1 I False I).
to see if the arrows and forall in the type of c1 are not fake.
All of this inspection could be made easier with a tool that displays
the content of .vo files in a structured way (e.g. an xml tree with all
kind of annotations) as opposed to a mere character sequence.
Bruno.
- [Coq-Club] how a client should check a Coq proof for cheating?, Georgi Guninski
- <Possible follow-ups>
- Re: [Coq-Club] how a client should check a Coq proof for cheating?, Bruno Barras
- Re: [Coq-Club] how a client should check a Coq proof for cheating?, Georgi Guninski
- [Coq-Club] an update to "Univalent Foundations",
Vladimir Voevodsky
- Re: [Coq-Club] an update to "Univalent Foundations",
Carlos Simpson
Vladimir Voevodsky
- Re: [HoTT] Re: [Coq-Club] an update to "Univalent Foundations",
Thomas Streicher
Carlos Simpson
- Re: [HoTT] Re: [Coq-Club] an update to "Univalent Foundations", Thomas Streicher
Carlos Simpson
Thomas Streicher
Vladimir Voevodsky
Carlos Simpson
