coq-club - Re: [Coq-Club] an update to "Univalent Foundations"
chronological Thread
  • To: Carlos Simpson <Carlos.Simpson AT unice.fr>
  • Cc: Coq-Club Club <coq-club AT inria.fr>, homotopytypetheory AT googlegroups.com
  • Subject: Re: [Coq-Club] an update to "Univalent Foundations"
  • Date: Tue, 17 May 2011 16:56:26 -0400
Hi Carlos,
my foundations setup is grounded in ZFC through what I call the univalent
model of type theory. Formalizing this model is an important and interesting
undertaking.  It can be done in a subset of Coq which does  not use
universes. This is a whole area of work which has to be done.
The way I see it one needs first to formalize the language of coq in a much
more simple type theory and then inside this "decidable" type theory to build
the required models.
A non-formal description of  the univalent model can be found on my website
in "Notes on Type Systems".
Very best,
Vladimir.
On May 17, 2011, at 4:48 PM, Carlos Simpson wrote:
> Dear Vladimir,
>  Can we do usual ZFC set theory (maybe with one or two Grothendieck-Tarski
> universes) in your foundational setup?
> If so, is there then furthermore a way of relating it to the more
> general types you consider?
> Thanks
> ---Carlos
> Selon Vladimir Voevodsky
> <vladimir AT ias.edu>:
>> Hello,
>> I have just posted an update to the "Univalent Foundations" library to my
>> github at https://github.com/vladimirias/Foundations/
>> The most important new thing in this release is the construction of true
>> set-quotients of types.
>> Vladimir.
