- To: Adam Chlipala <adam AT chlipala.net>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Is the Daniel Schepler's inconsistency real?
- Date: Sat, 25 Jun 2011 17:37:50 +0300
- Header: best read with a sniffer
On Sat, Jun 25, 2011 at 09:34:05AM -0400, Adam Chlipala wrote:
> Georgi Guninski wrote:
> >if you read the message you would realize i was asking about
> >*modifications* of his code. here are two files - one takes T as axiom,
> >the other takes ~T as axiom and in both cases False is proven (one of
> >the proofs should be real unless i miss something)
> Neither proof is showing an inconsistency in Coq. Rather, you've
> shown that [uat_maximal_card] is an inconsistent axiom even by
> itself, and [uat_not_maximal_card] is inconsistent with
> [eq_rect_eq].
If you examine the coq output, you will find out in both cases:
~uat_maximal_card = uat_not_maximal_card
Any ideas on simplifying your statement?
Note I probably need excluded middle.
Note that you can try to prove axioms by removing the comments...
- [Coq-Club] Is the Daniel Schepler's inconsistency real?, Georgi Guninski
- Re: [Coq-Club] Is the Daniel Schepler's inconsistency real?,
Adam Chlipala
Georgi Guninski
Adam Chlipala
- Re: [Coq-Club] Is the Daniel Schepler's inconsistency real?, Georgi Guninski
Adam Chlipala
Georgi Guninski
- Re: [Coq-Club] Is the Daniel Schepler's inconsistency real?, Adam Chlipala
- Re: [Coq-Club] Is the Daniel Schepler's inconsistency real?, Mathieu Boespflug
Georgi Guninski
Adam Chlipala
Adam Chlipala
- Re: [Coq-Club] Is the Daniel Schepler's inconsistency real?, gallais @ ensl.org
Georgi Guninski
Adam Chlipala
- [Coq-Club] Re: Is the Daniel Schepler's inconsistency real?,
Daniel Schepler
- Message not available
- Re: [Coq-Club] Re: Is the Daniel Schepler's inconsistency real?,
Daniel Schepler
- Re: [Coq-Club] Re: Is the Daniel Schepler's inconsistency real?, Georgi Guninski
Daniel Schepler
