- To: Georgi Guninski <guninski AT guninski.com>
- Cc: coq-club AT inria.fr
- Subject: [Coq-Club] Re: Is the Daniel Schepler's inconsistency real?
- Date: Sat, 25 Jun 2011 09:41:11 -0700
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=from:to:subject:date:user-agent:cc:references:in-reply-to :mime-version:content-type:content-transfer-encoding:message-id; b=rOxoAT0Ioiqwcv8e+uci8SXxAdWEe0BZsd4qduHNcv486oqAhHnLTFxnjYrndQDdv2 uvWS1T9Aa30XGj8ZMW7F3623uRfyb4hF4rwL8rkMB4iz9W2o/5K0cqpcmArp8/EC31qc udXaUOfyVj+k/RaOI0fxbxzmTplIXHBP4yiFs=
> Daniel Schepler proved [1][2] both T and ~T using only a plausible axiom
> and I couldn't find any cheating in his proof (I admit I am dumb).
> Possibly due to a coq ``anomaly'' (read a bug) coq gives strange error when
> using both T and ~T (well maybe coded on purpose)
> In his code T and ~T are [uat_maximal_card] and [uat_not_maximal_card].
> Assuming excluded middle, does it mean one of T and ~T is necessarily true
> so it can be taken as an axiom?
> According to my tests if I take as an axiom one of them, in *both* cases I
> can prove False using exactly his approach. One of the proofs will have
> axiom False (genuinely proved by him but unusable due to a bug), but the
> other must be real inconsistency.
> For testing I just replaced [Lemma] by [Axiom] and commented out the
> proof (leaving the proof for the contrary).
> Is this correct?
Let me try to explain what the "paradox" is that I'm formalizing, and what
the
resolution is. I forget the exact name of the paradox, but it's essentially
the Burali-Forti paradox with cardinals instead of ordinals. If you
formulate
it in ZFC, getting two contradictory statements about the cardinality of the
collection V of all sets, it's also closely related to the Russell paradox if
you unfold Cantor's diagonalization argument.
Essentially, if you let U be the disjoint union of all types, and consider
the
cardinality mu of U, then you can seem to get two contradictory statements
about it. First, for any cardinality kappa which is the cardinality of a
type
X, you obviously have an injection from X to U by the inclusion map.
Therefore, kappa <= mu [uat_maximal_card]. But by Cantor diagonalization,
2^mu > mu [uat_not_maximal_card].
Here, the key to resolving the apparent paradox is to consider Coq's type
hierarchy closely. Suppose the Type in the definition of union_of_all_types
is
Type(n). Then union_of_all_types is in Type(n+1). Now, in the proof of
uat_maximal_card, we feed X as an argument of type_inc. In order for this to
be valid, the Type in the statement of uat_maximal_card must be at level
Type(n) or lower. On the other hand, in the proof of uat_not_maximal_card,
we
feed (union_of_all_types -> Prop) into X, which is in Type(n+1), so for this
statement to be valid the Type here must be Type(n+1) or higher. If you turn
on display of universe levels just before trying to process the Qed of
contradiction, Coq will print an error message like
Error: Universe inconsistency (cannot enforce Top.8 = Top.61).
Here Top.8 is the level of Type in uat_maximal_card and Top.61 is the level
of
Type in uat_not_maximal_card. It wants the two levels to be equal in order
to
be able to derive the contradiction False, while internally it must have
found
restraints that imply that Top.8 < Top.61.
So as another way of saying it, all this argument proves is that it would be
inconsistent to assign union_of_all_types to the same level universe
represented by the Type level in the declaration in type_inc (or lower). But
if you "Print union_of_all_types." with universe level printing on, it shows
Inductive union_of_all_types : Type (* (Top.2)+1 *) :=
type_inc : forall X : Type (* Top.2 *), X -> union_of_all_types
So Coq got the universe level right.
Daniel
- [Coq-Club] Is the Daniel Schepler's inconsistency real?, Georgi Guninski
- Re: [Coq-Club] Is the Daniel Schepler's inconsistency real?,
Adam Chlipala
Georgi Guninski
Adam Chlipala
Georgi Guninski
Adam Chlipala
Georgi Guninski
- Re: [Coq-Club] Is the Daniel Schepler's inconsistency real?, Adam Chlipala
- Re: [Coq-Club] Is the Daniel Schepler's inconsistency real?, Mathieu Boespflug
Georgi Guninski
Adam Chlipala
Georgi Guninski
Adam Chlipala
- Re: [Coq-Club] Is the Daniel Schepler's inconsistency real?, gallais @ ensl.org
Georgi Guninski
Adam Chlipala
- [Coq-Club] Re: Is the Daniel Schepler's inconsistency real?, Daniel Schepler
- Message not available
- Re: [Coq-Club] Re: Is the Daniel Schepler's inconsistency real?,
Daniel Schepler
- Re: [Coq-Club] Re: Is the Daniel Schepler's inconsistency real?, Georgi Guninski
Daniel Schepler
