- From: "Ly Kim Quyen (Gwenhael)" <lykimq AT gmail.com>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] Asking about dependence type
- Date: Mon, 27 Jun 2011 16:52:55 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:from:date:message-id:subject:to:content-type; b=JAGXznVJ4KsM1XX5zfTAzaRztcyCJKYYdHg4ccuvzqGD3cb4yYasrXdYE1OnZ8Iqzd UGDhCax4uRMBI70bgUj8QcVxiAXc3zBexycqIdb6Z4wthpJIOaQ7Fblf221ZXXnCrElU cKh22wKUkYdGLg86FhR78v5HdQWrjwqYDCxUQ=
Hello,
I have a question about an dependent type.
I have a function poly_symbol is:
Fixpoint poly_symbol ( l : list {g: symbol & poly (arity g)}) : poly (arity f) :=
match l with
| existT g p :: l' =>
match eq_symb_dec f g with
| left h => poly_cast h p
| right _ => poly_symbol l'
end
| nil => default_poly (arity f)
end.
where eq_symb_dec: forall f g : symbol, {f = g} + {f <> g}
arity : symbol -> nat.
poly: nat -> Set.
I want to define the function poly_cast which a specification is:
poly_cast: forall n m : nat, if n = m then poly n = poly m.
Here is my definition :
Definition poly_cast {n : nat} {m : nat} (x : n = m) :=
match x with
| h => poly n = poly m
end.
I know it is not good function of what I want because when I apply it to the function poly_symbol it gives me an error at : poly_cast h
The term "h" has type "f = g" while it is expected to have type "?3478 = ?3479".
Could you please give me some suggestion how to build the function poly_cast?
I would like to learn more about how to build a function and dependence type function.
Thank you very much,
Gwen
- [Coq-Club] Asking about dependence type, Ly Kim Quyen (Gwenhael)
- Re: [Coq-Club] Asking about dependence type, gallais @ ensl.org
AUGER Cedric
- Re: [Coq-Club] Asking about dependence type, Ly Kim Quyen (Gwenhael)
