- From: "Ly Kim Quyen (Gwenhael)" <lykimq AT gmail.com>
- To: AUGER Cedric <Cedric.Auger AT lri.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Asking about dependence type
- Date: Tue, 28 Jun 2011 11:10:57 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :cc:content-type; b=hJuGd4TsBUQL+7ygVbu7pZbMipyTXuDhqYZxn22XOilWG5FJn3bmvEjpqTgMxZYVBm Wz7I4MGi5hMC79IJTf9TdplSburjvM0xM8HcQkXr9q0e1VSSxDag4tpUiSpwekZNv1y8 whh8splZYC/7FS+0w7RKMlJHs7cCj+I5yVMT4=
Hello Cedric,
I have tried to define the definition poly_cast from your hint.
Definition poly_cast n m (Heq: n = m)(p: poly n) : poly m.
rewrite <- Heq; hyp. Defined.
and also
Definition poly_cast' {n m} {Heq: n = m} {p : poly m} :=
match Heq in _ = n0 return poly n0 -> Prop with
| h => fun p0 => p = p0
end p.
From definitions above when I apply it to the function poly_symbol I get the same error at poly_cast h:
f: symbol
p : (fun g : symbol => poly (arity g)) g
h : f = g
The term "h" has type "f = g" while it is expected to have type "?1733 = ?1734"
Fixpoint poly_symbol ( l : list {g: symbol & poly (arity g)}) : poly (arity f) :=
match l with
| existT g p :: l' =>
match eq_symb_dec f g with
| left h => poly_cast h p
| right _ => poly_symbol l'
end
| nil => default_poly (arity f)
end.
In my definition of poly_symbol it return the type poly (arity f), and the function poly_cast waiting the condition (h : f = g) p and return a type poly (arity f).
If I am using the function poly_cast' which type: forall n m : nat, n = m -> poly m -> Prop how can I change the definition of poly_symbol at left h? because it will return Prop but I want it return poly (arity g) for f = g.
Thank you,
Gwen
On 27 June 2011 18:46, AUGER Cedric <Cedric.Auger AT lri.fr> wrote:
Le Mon, 27 Jun 2011 16:52:55 +0800,
"Ly Kim Quyen (Gwenhael)" <lykimq AT gmail.com> a écrit :
I guess that what you want is rather a function poly_cast of type:
> Hello,
> I have a question about an dependent type.
> I have a function poly_symbol is:
> (arity f) :=
> match l with
> | existT g p :: l' =>
> end
> end.
> where eq_symb_dec: forall f g : symbol, {f = g} + {f <> g}
> arity : symbol -> nat.
> poly: nat -> Set.
> I want to define the function poly_cast which a specification is:
> poly_cast: forall n m : nat, if n = m then poly n = poly m.
> Here is my definition :
> Definition poly_cast {n : nat} {m : nat} (x : n = m) :=
> match x with
> | h => poly n = poly m
> end.
> I know it is not good function of what I want because when I apply it
> to the function poly_symbol it gives me an error at : poly_cast h
> "?3478 = ?3479".
> Could you please give me some suggestion how to build the function
> poly_cast?
> I would like to learn more about how to build a function and
> dependence type function.
> Thank you very much,
> Gwen
∀ n, poly n → ∀ m, n = m → poly m.
for which you can prove that:
∀ n m, n = m → ∀ p, JMeq.jmeq p (poly_cast p).
(or if you prefer:
∀ n m (H: n = m) (p: poly m),
match H in _=n0 return poly n0 → Prop with
end p)
Given this hint, I hope you can find one.
Don't forget, that you can create your functions using tactics, end
them with Defined, and eventually print them to understand how Coq
builds them.
When I want to experiment these features, I often do a:
Goal forall p, p = [my_tactically_built_function].
unfold [my_tactically_built_function].
… being often a sequence of "unfold [coq_term]", "simpl",
"cbv delta/iota/zeta/beta [args]" and so on.
For instance, with poly_cast using my specification, you can do:
Definition poly_cast n (p: poly n) m (Heq:n=m): poly m.
rewrite <- Heq.
assumption.
Defined.
I let you explore what it does (I really don't like the use of eq_ind
in generated proof terms, but I found that the vo file is shorter for
a definition using eq_ind than for a definition using "match with").
- [Coq-Club] Asking about dependence type, Ly Kim Quyen (Gwenhael)
- Re: [Coq-Club] Asking about dependence type, gallais @ ensl.org
AUGER Cedric
- Re: [Coq-Club] Asking about dependence type, Ly Kim Quyen (Gwenhael)
