coq-club - [Coq-Club] How to make the tactic ring use my ring structure?
chronological Thread
  • From: "Lucian M. Patcas" <lucian.patcas AT gmail.com>
  • To: coq-club <coq-club AT inria.fr>
  • Subject: [Coq-Club] How to make the tactic ring use my ring structure?
  • Date: Mon, 27 Jun 2011 13:47:28 -0400
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:reply-to:sender:from:date:x-google-sender-auth :message-id:subject:to:content-type; b=o/WfW4VDIDpC5wHTzsGWzmdD+bhZeodpooJwwvJAZ1v1+xanrIQrwdC6WVkDC3cMpU tyyLpBBY6XagED5DB5mhz+evoU0YicIzFau3deAocyv5wEm9Wpj8M3oMtg4pHchMX1Oc R4Vh5zyzYiIRlqTmfKMjHITE9Bz9x3n4dSimQ=
Hi all,
I need to define a ring structure and convince the ring tactic to use it. I looked in the manual and in the module Ring_theory. I also looked at how nat is "registered" as a ring in Coq.setoid_ring.ArithRing, but I still don't know how exactly to define a ring structure and how to use Add Ring. Perhaps I'm missing something. Can someone help out?
Require
  Import Mult.
Require Import BinNat.
Require Import Nnat.
Require Export Ring.
Lemma natSRth : semi_ring_theory O (S O) plus mult (@eq nat).
Lemma nat_morph_N :
   semi_morph 0 1 plus mult (eq (A:=nat))
          0%N 1%N Nplus Nmult Neq_bool nat_of_N.
Ltac natcst t :=
  match isnatcst t with
    true => constr:(N_of_nat t)
  | _ => constr:InitialRing.NotConstant
  end.
Ltac Ss_to_add f acc :=
  match f with
  | S ?f1 => Ss_to_add f1 (S acc)
  | _ => constr:(acc + f)%nat
  end.
Ltac natprering :=
  match goal with
    |- context C [S ?p] =>
    match p with
      O => fail 1
    | p => match isnatcst p with
           | true => fail 1
           | false => let v := Ss_to_add p (S 0) in
                         fold v; natprering
           end
    end
  | _ => idtac
  end.
Add Ring natr : natSRth
  (morphism nat_morph_N, constants [natcst], preprocess [natprering]).
Thanks,
Lucian
