coq-club - [Coq-Club] Asking about boolean equality function
chronological Thread
  • From: "Ly Kim Quyen (Gwenhael)" <lykimq AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Asking about boolean equality function
  • Date: Mon, 25 Jul 2011 10:27:21 +0800
Dear Club,
I have these code:
Require Import Bool VecUtil ZArith ListForall List.  (*VecUtil and ListForall are the library in CoLoR project (http://color.inria.fr/doc/main.html) *)
Notation monom := (vector nat).
Definition poly n := list (Z * monom n).
Open Local Scope Z_scope.
Definition is_not_neg z :=
  match z with
    | Zneg _ => false
    | _ => true
  end.
Definition coef_pos n (p : poly n) := lforall (fun x => 0 <= fst x) p.
Definition bcoef_pos n (p : poly n) := forallb (fun x => is_not_neg (fst x)) p.
Lemma bcoef_pos_ok : forall n (p : poly n), bcoef_pos n p = true <-> coef_pos n p.
Proof.
Admitted.
Lemma bcoef_pos_ok_2 : forall n (p : poly n), bcoef_pos n p = true -> coef_pos n p.
Proof.
Admitted.
Record poly_mon n : Type := Build_poly_mon
      { p_poly : poly n;
        pweak_mon_check : coef_pos n p_poly
Definition check n p : poly_mon n :=
  match bool_dec (bcoef_pos n p) true with
    | left h => Build_poly_mon n p (bcoef_pos_ok n p h)
    | right _ => _ (* whatever *)
  end.
My question is: Why I cannot apply the lemma bcoef_pos_ok in this definition?
I got the error saying that: "The _expression_ "bcoef_pos_ok n p" of type  "bcoef_pos n p = true <-> coef_pos n p"
cannot be applied to the term  "h0" : "bcoef_pos n p = true"
But if I am using the lemma bcoef_pos_ok_2 it works.
Thank you very much,
Gwen
