- To: coq-club AT inria.fr
- Subject: [Coq-Club] Error: The correctness of the conclusion relies on the body of b
- Date: Sun, 14 Aug 2011 18:12:24 -0700
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
I was working on the attached proof file.
(I've cut out unnecessary proofs, so it should just have the main line.)
Then I tried this:
Theorem permutation_12 n r: permutation n r = permutation2 n r.
unfold permutation.
unfold permutation2.
destruct (leb r n) as [] _eqn.
(Note: leb needs "Require Import Arith.".)
But, destruct gives me the error:
What does that mean?
If I try a different order:
unfold permutation.
rewrite Heqb.
"fun b : bool =>
(if b as l return (b = l -> nat)
which is ill-typed.
How do I do case analysis here?
Is there an easy way to rewrite it to avoid this problem?
Or is there a tactic to address this?
I looked around a bit and one place recommended defining
a Scheme for the case, then destruct using that.
(But, unfortunately, I don't have enough of an understanding
of the formalisms to know what that actually means.)
Does it have to do with how I have an extra lambda to
pass the eq_refl in to reason about which case of
the match expression I'm in?
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.17 (GNU/Linux)
Comment: Using GnuPG with Gentoo - http://enigmail.mozdev.org/
iEYEARECAAYFAk5IcngACgkQxzVgPqtIcftNQwCfZLCYDV98oCjtP9ReTdgdXBGK
U50An2tjb0VOl6AbnrpzU/y08j0CS2A9
=qaqG
-----END PGP SIGNATURE-----
Require Import Recdef.
Require Import Setoid.
Theorem le_inc_both n m: n <= m -> S n <= S m.
simpl_relation.
Qed.
Function divmod (n m: nat) (p: m > 0) {measure id n}: nat * nat :=
if leb m n
then
let x := divmod (n - m) m p in
(S (fst x), snd x)
else (0, n).
intros.
unfold id.
destruct m.
inversion p.
destruct n.
discriminate teq.
unfold lt.
simpl.
clear p teq.
apply le_inc_both.
apply le_minus.
Defined.
Inductive divides n: nat -> Prop :=
| divides_0: divides n 0
| divides_n m: divides n m -> divides n (m + n)
Definition exactdiv n m p (q: divides m n) := fst (divmod n m p).
Theorem divides_mult n m: divides n (n * m).
induction m.
rewrite mult_0_r.
apply divides_0.
rewrite mult_succ_r.
apply divides_n.
apply IHm.
Qed.
Theorem divides_exists n m: divides n m -> exists p, m = n * p.
intros.
induction H.
exists 0.
rewrite mult_0_r.
tauto.
inversion_clear IHdivides.
rewrite H0.
clear H0 m H.
exists (S x).
tauto.
Qed.
Definition permutation (n r: nat): nat.
refine (
(if leb r n as l return (leb r n = l -> nat)
then fun _ => exactdiv (fact n) (fact (n - r)) _ _
else fun _ => 0
) (eq_refl (leb r n))
apply lt_O_fact.
apply leb_complete in _H.
apply le_plus_minus in _H.
pattern n at 2.
rewrite _H.
clear _H.
assert (exists a : _, n - r = a).
exists (n - r).
tauto.
inversion_clear H.
rewrite H0.
clear H0 n.
induction r.
simpl.
rewrite plus_n_O.
rewrite plus_comm.
apply divides_n.
apply divides_0.
simpl.
pattern (fact (r + x)) at 1.
rewrite <- mult_1_l.
rewrite <- mult_plus_distr_r.
rewrite mult_comm.
apply divides_exists in IHr.
inversion_clear IHr.
rewrite H.
clear H.
rewrite <- mult_assoc.
apply divides_mult.
Defined.
Fixpoint permutation2l n i p :=
match i with
| 0 => p
| S q => permutation2l n q ((n - q) * p)
end
Definition permutation2 n r :=
if leb r n
then permutation2l n r 1
else 0
(* This part fails
unfold permutation.
perm.v.sig
Description: PGP signature
- [Coq-Club] Error: The correctness of the conclusion relies on the body of b, S3
- Re: [Coq-Club] Error: The correctness of the conclusion relies on the body of b,
Adam Chlipala
- Message not available
Adam Chlipala
