Re: [Coq-Club] Error: The correctness of the conclusion relies on the body of b
chronological Thread
- To: Adam Chlipala <adamc AT csail.mit.edu>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Error: The correctness of the conclusion relies on the body of b
- Date: Mon, 15 Aug 2011 23:30:41 -0700
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
> S3 wrote:
>> Theorem permutation_12 n r: permutation n r = permutation2 n r.
>> unfold permutation.
>> unfold permutation2.
>> destruct (leb r n) as [] _eqn.
> In situations like this, it is useful to break the operation of [destruct]
into stages. Your example fails in the very first stage.
> To simulate that stage, run:
> generalize (leb r n).
> This tactic just tries to replace all occurrences of the term with a fresh
variable. The error message reveals that the result is ill-typed, due to a
use
of [leb_complete], one of whose arguments is typed in terms of [leb]. Because
you replace a use of [leb], that argument assumes an improper type.
> The easiest solution I know is to run [generalize (leb_complete r n)] first.
Then your original strategy works.
Thanks! I tried that and was able to prove the rest fairly directly.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.17 (GNU/Linux)
Comment: Using GnuPG with Gentoo - http://enigmail.mozdev.org/
iEYEARECAAYFAk5KDpAACgkQxzVgPqtIcfvJ+QCeNhO0iia0X58pgY/OA6CTt2l0
gYgAn2NSKa7h4dUCyPIAfak7OblmFq/g
=upPZ
-----END PGP SIGNATURE-----
- [Coq-Club] Error: The correctness of the conclusion relies on the body of b, S3
- Re: [Coq-Club] Error: The correctness of the conclusion relies on the body of b,
Adam Chlipala
- Message not available
- Re: [Coq-Club] Error: The correctness of the conclusion relies on the body of b, S3
Adam Chlipala
