coq-club - Re: [Coq-Club] Error: The correctness of the conclusion relies on the body of b
chronological Thread
  • To: S3 <scubed2 AT gmail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Error: The correctness of the conclusion relies on the body of b
  • Date: Mon, 15 Aug 2011 07:58:18 -0400
S3 wrote:
Theorem permutation_12 n r: permutation n r = permutation2 n r.
   unfold permutation.
   unfold permutation2.
   destruct (leb r n) as [] _eqn.
In situations like this, it is useful to break the operation of [destruct] into stages. Your example fails in the very first stage.
To simulate that stage, run:
    generalize (leb r n).
This tactic just tries to replace all occurrences of the term with a fresh variable. The error message reveals that the result is ill-typed, due to a use of [leb_complete], one of whose arguments is typed in terms of [leb]. Because you replace a use of [leb], that argument assumes an improper type.
The easiest solution I know is to run [generalize (leb_complete r n)] first. Then your original strategy works.
