- To: adamc AT csail.mit.edu
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] [Coq Club]a strange question when using function
- Date: Thu, 25 Aug 2011 10:58:59 +0800
thanks for your reply!
when proving lemma "existselement", i do "induction d" and "simpl", then Coq
system produce a paticular "e0:e" and replace "d" with "(DE e0)". That's why
you see such a particular constant string.
What confuse me is the difference when Coq compute the "interp" function. if
i do:
Compute (interp (DE "e0")).
then i can get the following result which is what i expect :
= (("e0" :: nil) :: nil) :: nil
: m
but when do "induction d" and "simpl" in lemma "existselement", i get a
different result:
((e0 :: nil) :: nil)
which i think is wrong.
because due to definition ,the type of m should be set (set (list string)).
------------------ ÔʼÓʼþ ------------------
>From: Adam Chlipala
><adamc AT csail.mit.edu>
>Reply-To:
>To:
>ldou AT cs.ecnu.edu.cn
>Date: Wed, 24 Aug 2011 10:47:53 -0400
> wrote:
>> the result turns out to be:
>> exists o' : o, (if o_dec o' ((e0 :: nil) :: nil) then true else false)
>> = true
>> but it should be :
>> exists o' : o, (if o_dec o' ((("e0" :: nil) :: nil) ::nil) then true
>> else false) = true
>> Why is that?
>Can you explain why you expected a different result? This looks correct
>to me. Why would you expect an arbitrary [Diag] to be known to contain a
>particular constant string?
Hi,everyone. I just meet a strange issue below:
Require Import String Bool ListSet List Classical.
Open Scope nat_scope.
Open Scope type_scope.
Open Scope string_scope.
Open Scope list_scope.
Definition e:=string.
Definition t := list e.
Definition o := set t.
Definition m:=set o.
Definition o_dec:forall (a b:o) ,{a = b} + {a <> b}.
repeat decide equality.
Defined.
Inductive Diag:Set :=
DE: e->Diag.
Fixpoint interp (D:Diag) {struct D}: m :=
match D with
|DE e => ((e::nil)::nil)::nil
end.
Lemma test: set_mem o_dec
(("e0" :: nil) :: nil) ((("e0" :: nil) :: nil) ::nil)=true.
Proof.
simpl. auto.
Qed.
Lemma existselement:forall d:Diag,
exists o':o, set_mem o_dec o' (interp d )=true.
Proof.
intro d.
induction d. simpl.
the problem is :when do simpl in existselement, the result turns out to be:
exists o' : o, (if o_dec o' ((e0 :: nil) :: nil) then true else false) = true
but it should be :
exists o' : o, (if o_dec o' ((("e0" :: nil) :: nil) ::nil) then true else
false) = true
Why is that?
- [Coq-Club] [Coq Club]a strange question when using function, ldou
- <Possible follow-ups>
- Re: [Coq-Club] [Coq Club]a strange question when using function, ldou
- Re: [Coq-Club] [Coq Club]a strange question when using function, Pierre Casteran
- Re: [Coq-Club] [Coq Club]a strange question when using function, Adam Chlipala
ldou
