- To: ldou AT cs.ecnu.edu.cn
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] [Coq Club]a strange question when using function
- Date: Thu, 25 Aug 2011 08:04:40 -0400
wrote:
> when proving lemma "existselement", i do "induction d" and "simpl", then
> Coq system produce a paticular "e0:e" and replace "d" with "(DE e0)".
> That's why you see such a particular constant string.
I don't call [e0] there a constant string. ["e0"] would be a constant
string.
> What confuse me is the difference when Coq compute the "interp" function.
> if i do:
> Compute (interp (DE "e0")).
> then i can get the following result which is what i expect :
> = (("e0" :: nil) :: nil) :: nil
> : m
> but when do "induction d" and "simpl" in lemma "existselement", i get a
> different result:
> ((e0 :: nil) :: nil)
> which i think is wrong.
Pierre already sent a solution, so I won't go into much more detail
here, except to reiterate that Pierre and I are pretty sure that there
is nothing wrong with this output, and the version you expected would be
wrong. Perhaps the problem here is a misunderstanding of the meaning of
double quotes in Coq? I asked you before why you expected a different
outcome, but your message that I'm replying to doesn't seem to answer
that question. Why would you think that [interp (DE "e0")] would yield
the same term as your [induction] call?
- [Coq-Club] [Coq Club]a strange question when using function, ldou
- <Possible follow-ups>
- Re: [Coq-Club] [Coq Club]a strange question when using function,
ldou
- Re: [Coq-Club] [Coq Club]a strange question when using function, Pierre Casteran
- Re: [Coq-Club] [Coq Club]a strange question when using function, Adam Chlipala
ldou
- Re: [Coq-Club] [Coq Club]a strange question when using function, ldou
