- To: coq-club AT inria.fr
- Subject: [Coq-Club] [Coq Club]a strange question when using function
- Date: Wed, 24 Aug 2011 22:33:56 +0800
Hi,everyone. I just meet a strange issue below:
Require Import String Bool ListSet List Classical.
Open Scope nat_scope.
Open Scope type_scope.
Open Scope string_scope.
Open Scope list_scope.
Definition e:=string.
Definition t := list e.
Definition o := set t.
Definition m:=set o.
Definition o_dec:forall (a b:o) ,{a = b} + {a <> b}.
repeat decide equality.
Defined.
Inductive Diag:Set :=
DE: e->Diag.
Fixpoint interp (D:Diag) {struct D}: m :=
match D with
|DE e => ((e::nil)::nil)::nil
end.
Lemma test: set_mem o_dec
(("e0" :: nil) :: nil) ((("e0" :: nil) :: nil) ::nil)=true.
Proof.
simpl. auto.
Qed.
Lemma existselement:forall d:Diag,
exists o':o, set_mem o_dec o' (interp d )=true.
Proof.
intro d.
induction d. simpl.
the problem is :when do simpl in existselement, the result turns out to be:
exists o' : o, (if o_dec o' ((e0 :: nil) :: nil) then true else false) = true
but it should be :
exists o' : o, (if o_dec o' ((("e0" :: nil) :: nil) ::nil) then true else false) = true
Why is that?
- [Coq-Club] [Coq Club]a strange question when using function, ldou
- <Possible follow-ups>
- Re: [Coq-Club] [Coq Club]a strange question when using function,
ldou
- Re: [Coq-Club] [Coq Club]a strange question when using function, Pierre Casteran
- Re: [Coq-Club] [Coq Club]a strange question when using function, Adam Chlipala
ldou
- Re: [Coq-Club] [Coq Club]a strange question when using function, ldou
