- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] I am cautious about adding some axioms
- Date: Sat, 27 Aug 2011 08:20:38 -0400
Pierre-Marie Pedrot wrote:
Choice operator is inconsistent in Type Theory; you must assume that A is inhabited in realize, as :
Parameter realize : forall (A : Type), inhabited A -> (A -> Prop) -> A.
See the standard library Epsilon* modules for more informations.
I think it's worth pointing out that this whole class of "Axiom of Choice"-style functions is much less interesting in Coq than in mainstream math. An axiom like [realize] only becomes similarly interesting when you add other axioms of a classical flavor, like the law of the excluded middle. This is because [inhabited A] still requires a constructive proof of the existence of a member of [A], which implies the existence of an algorithm for computing that member, so why bother using realize! (The same holds true in versions that also require a proof that there exists (possibly a unique) element of [A] satisfying a predicate.)
With the law of the excluded middle, the [inhabited] proof effectively gains the ability to use a richer notion of computation. Even without such an axiom, it already has a richer notion than in [Set], because [Prop] allows impredicativity, but my suspicion is that few proofs make deep use of impredicativity. (Does anyone have a non-contrived counterexample to that suspicion?)
- [Coq-Club] I am cautious about adding some axioms, ±èÇü¼±
- Re: [Coq-Club] I am cautious about adding some axioms,
Pierre-Marie Pedrot
- Re: [Coq-Club] I am cautious about adding some axioms, Adam Chlipala
Jean-Francois Monin
Jean-Francois Monin
- Re: [Coq-Club] I am cautious about adding some axioms, AUGER Cedric
Pierre-Marie Pedrot
