- To: Jean-Francois Monin <jean-francois.monin AT imag.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] I am cautious about adding some axioms
- Date: Tue, 30 Aug 2011 08:08:00 -0400
Jean-Francois Monin wrote:
You may have a look in the contribs from Lannion about exceptions,
and my related paper in SCP.
In summary, it is a kind of CPS translation where the result and its
type need to be local (rather than global as usual). In particular,
for ensuring modularity: a function raising an exception has a meaning
indepandantly from its context. When a recursive call is embedded
inside a "try with" construct, impredicativity comes naturally into
play.
The contrib uses impredicative Set.
On Sat, Aug 27, 2011 at 08:20:38AM -0400, Adam Chlipala wrote:
Even without such an axiom, it already has a richer notion than in
[Set], because [Prop] allows impredicativity, but my suspicion is
that few proofs make deep use of impredicativity. (Does anyone have
a non-contrived counterexample to that suspicion?)
I don't doubt that impredicativity can be useful for modeling impredicative polymorphism in programming languages, which I'm guessing is a reasonable explanation of what happens in your development. My original curiosity was about impredicativity in [Prop], not [Set], though.
- [Coq-Club] I am cautious about adding some axioms, ±èÇü¼±
- Re: [Coq-Club] I am cautious about adding some axioms,
Pierre-Marie Pedrot
Adam Chlipala
Jean-Francois Monin
- Re: [Coq-Club] I am cautious about adding some axioms, Adam Chlipala
Jean-Francois Monin
- Re: [Coq-Club] I am cautious about adding some axioms, AUGER Cedric
Adam Chlipala
Pierre-Marie Pedrot
