- To: Coq-Club Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Error: A fixpoint needs at least one parameter.
- Date: Thu, 22 Sep 2011 01:03:37 -0400
What does this error message mean? Consider the following code in Coq 8.3pl2:
Reset Initial.
Set Implicit Arguments.
Inductive sort : Set := Name | Lam.
Definition var := (prod nat sort).
Inductive trm : sort -> Set :=
| ivar : forall (x:var), trm (snd x)
| aply : forall (K:trm Lam) (M:trm Lam), trm Lam.
Fixpoint trmFV (s:sort) (X:trm s) {struct X} : list var :=
match X with
| ivar x => cons x nil
| aply K M => app (trmFV K) (trmFV M)
end.
Inductive fsort : Set := prop | aprop.
Inductive fmla : fsort -> Set :=
| feq: forall (s:sort) (t u: trm s), fmla prop
| fand: forall (P Q:fmla prop), fmla prop.
Fixpoint fmlaFV: (fs:fsort) (X:fmla fs) {struct X} : list var :=
match X with
| feq t u => app (trmFV t) (trmFV u)
| fand P Q => app (fmlaFV P) (fmlaFV Q)
end.
The definition of termFV (free variables in a term) is accepted, but
the definition of fmlaFV (free variables in a formula) is rejected
with the error message above. I don't see the problem.
Thanks for any help.
Randy
- [Coq-Club] Error: A fixpoint needs at least one parameter., Randy Pollack
