coq-club - Re: [Coq-Club] Error: A fixpoint needs at least one parameter.
chronological Thread
  • From: Vincent Siles <vincent.siles AT ens-lyon.org>
  • To: Randy Pollack <rpollack0 AT gmail.com>
  • Cc: Coq-Club Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Error: A fixpoint needs at least one parameter.
  • Date: Thu, 22 Sep 2011 09:13:43 +0200
I'm not on a computer with Coq installed right now (what a shame, I
know), but if this is an
exact copy/paste of your problem, I guess the : just after fmlaFV is
the problem.
What's happening if you remove it ?
Best,
Vincent
2011/9/22 Randy Pollack
<rpollack0 AT gmail.com>:
> What does this error message mean?  Consider the following code in Coq
> 8.3pl2:
> Reset Initial.
> Set Implicit Arguments.
> Inductive sort : Set := Name | Lam.
> Definition var := (prod nat sort).
> Inductive trm : sort -> Set :=
> | ivar : forall (x:var), trm (snd x)
> | aply : forall (K:trm Lam) (M:trm Lam), trm Lam.
> Fixpoint trmFV (s:sort) (X:trm s) {struct X} : list var :=
>  match X with
>    | ivar x => cons x nil
>    | aply K M => app (trmFV K) (trmFV M)
>  end.
> Inductive fsort : Set := prop | aprop.
> Inductive fmla : fsort -> Set :=
> | feq: forall (s:sort) (t u: trm s), fmla prop
> | fand: forall (P Q:fmla prop), fmla prop.
> Fixpoint fmlaFV: (fs:fsort) (X:fmla fs) {struct X} : list var :=
>  match X with
>    | feq t u => app (trmFV t) (trmFV u)
>    | fand P Q => app (fmlaFV P) (fmlaFV Q)
>  end.
> The definition of termFV (free variables in a term) is accepted, but
> the definition of fmlaFV (free variables in a formula) is rejected
> with the error message above.  I don't see the problem.
> Thanks for any help.
> Randy
