- To: coq-club AT inria.fr
- Subject: [Coq-Club] Using Coq for formalization of mathematics
- Date: Fri, 23 Sep 2011 21:20:09 -0700
I'm thinking of writing a new tutorial on (plug subject in here). My
ambition
would be to have it be a sort of complement to Adam's CPDT book: where Adam
covers the programming side of using Coq, I'd focus more on the formal proofs
side.
A rough preliminary outline of what I'd cover would be:
* Introduction (currently, thinking of using some examples from basic group
theory).
* Using sections and multiple files.
* Typeclasses, along the lines of MathClasses -- and use these heavily
throughout the rest of the tutorial.
* Induction.
* Defining inductive types and inductive Props (mostly focusing on inductive
props, thinking of them as "the subset generated by some generators and
closure conditions"). Include a discussion on what it means to "use
induction
on an inductively defined Prop", since this is something that's likely to be
unfamiliar to most mathematicians.
* Subsets (both Ensembles library and subset types), and the Program
Definition
/ Lemma feature to make working with subset types more readable.
* An overview of the Howard-Curry isomorphism and its use in Coq, with a view
towards understanding how proof terms work and being able to write some basic
proof terms.
* A section going over some of the basic logical axioms available in the
standard library, and some personal philosophical musings on when to use the
axioms and when to try to avoid them if possible.
* A brief description of the type hierarchy.
* Introduction to proof automation, though almost certainly not going as far
as Adam goes. :) Probably leading up to an example I've worked out, of
proving associativity of addition on binary positive integers, where I'll go
through the development of an automated proof by extending what it tries
until
it can cover all 27 cases.
* Proof by reflection (a.k.a. "it's true because my certified CAS says so").
This would certainly be a good place for a reference to CPDT, for obvious
reasons.
One thing that I'd definitely want to cover is some examples where destruct
or
rewrite won't work because of dependent types, and how to handle these
situations. I can't think of any simple examples off the top of my head, but
it's definitely something that periodically comes up in my work. I'm also
not
sure where that would fit into the presentation.
Anyway, I'm wondering if there's interest in seeing this come to fruition, or
maybe some topics you'd like to see covered that I left out or forgot.
Daniel Schepler
- [Coq-Club] Using Coq for formalization of mathematics, Daniel Schepler
- Re: [Coq-Club] Using Coq for formalization of mathematics,
Benjamin C. Pierce
Daniel Schepler
- Re: [Coq-Club] Using Coq for formalization of mathematics, Adam Chlipala
- Re: [Coq-Club] Using Coq for formalization of mathematics, Benjamin C. Pierce
Daniel Schepler
- Message not available
Daniel Schepler
Adam Chlipala
Vladimir Voevodsky
Adam Chlipala
Vladimir Voevodsky
Vladimir Voevodsky
Adam Chlipala
Vladimir Voevodsky
Adam Chlipala
Daniel Schepler
Benjamin C. Pierce
