- To: Daniel Schepler <dschepler AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Using Coq for formalization of mathematics
- Date: Sat, 24 Sep 2011 13:09:28 -0400
Daniel Schepler wrote:
It's just that "induction on a proposition" isn't really part of the standard
mathematical language.
Perhaps you can view it as a public service task to help change that deficiency? ;)
As an example, take "<=" on the natural numbers. In Coq,<= is defined so that
for fixed a, { b:nat | a<= b } is the smallest subset of nat which contains a,
and such that whenever b is in the set, succ(b) is also.
Now consider the problem of proving that<= is transitive, i.e. if a<= b and
b<= c then a<= c. In Coq, the usual way to prove this would be "by
induction on b<= c". In standard mathematical language, this proof would be
translated as: suppose a<= b. Then { c:nat | a<= c } contains b; and by
definition, whenever c is in that set, succ(c) is also. Since { c:nat | b<= c
} is the smallest such set, it follows that { c:nat | b<= c } is a subset of
{ c:nat | a<= c }. We have now proved that a<= b -> ({ c:nat | b<= c } is
a subset of { c:nat | a<= c }), and if we unfold the definition of subset, we
get exactly the desired transitivity property.
So for mathematicians, it's probably easiest to think of "induction on a Prop"
as shorthand for this style of argument, "the set of values satisfying my
desired conclusion contains the generators and satisfies the closure relations
defining the set of values corresponding to some hypothesis".
Does any significant fraction of working mathematicians get into this level of detail about "<="? I would expect that instead they use perhaps normal mathematical induction on "a" and don't sweat the details.
- [Coq-Club] Using Coq for formalization of mathematics, Daniel Schepler
- Re: [Coq-Club] Using Coq for formalization of mathematics, Benjamin C. Pierce
- Message not available
Daniel Schepler
- Re: [Coq-Club] Using Coq for formalization of mathematics, Adam Chlipala
Vladimir Voevodsky
Adam Chlipala
Vladimir Voevodsky
- Re: [Coq-Club] Using Coq for formalization of mathematics, Vladimir Voevodsky
- Re: [Coq-Club] Using Coq for formalization of mathematics, Daniel Schepler
Vladimir Voevodsky
Adam Chlipala
Vladimir Voevodsky
Daniel Schepler
