- From: Andrew Pennebaker <andrew.pennebaker AT gmail.com>
- To: Coq <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Re: syntax confusion
- Date: Wed, 2 Nov 2011 21:03:37 -0400
Daniel, I'll check it out.
Adam, I started reading CPDT Chapter 3 and came up with this:
https://github.com/mcandre/mcandre/blob/master/coq/bertrand.v
Andrew Pennebaker
On Wed, Nov 2, 2011 at 7:49 PM, Daniel Schepler <dschepler AT gmail.com> wrote:
I've started working on a Coq tutorial focused more on mathematics formalization than on program verification. Right now, I only have the first chapter done, without even an introduction written (although I have a rough outline in mind for what I want to cover -- it hopefully shouldn't be too hard to find in the recent coq-club archives).
This first chapter starts off by declaring the "language/syntax" of the theory of groups, then declaring the "axioms", then proving several basic results using the axioms.
I'd be interested in any comments you might have about it.
Daniel Schepler
- Re: [Coq-Club] Re: syntax confusion, (continued)
Adam Chlipala
Andrew Pennebaker
Adam Chlipala
Andrew Pennebaker
- Re: [Coq-Club] Re: syntax confusion, Adam Chlipala
- Re: [Coq-Club] Re: syntax confusion, Andrew Pennebaker
- Message not available
- Re: [Coq-Club] Re: syntax confusion, Daniel Schepler
Andrew Pennebaker
Adam Chlipala
Andrew Pennebaker
Adam Chlipala
