- From: Andrew Pennebaker <andrew.pennebaker AT gmail.com>
- To: Coq <coq-club AT inria.fr>
- Subject: [Coq-Club] SF, Fibonacci, and "Error: This clause is redundant."
- Date: Thu, 3 Nov 2011 15:12:32 -0400
I'm following the Software Foundations tutorial, and I decided to write a fibonacci function.
Inductive nat : Set :=
| O : nat
| S : nat -> nat.
Fixpoint plus (n m : nat) : nat :=
match n with
| O => m
| S n' => S (plus n' m)
end.
Fixpoint mult (n m : nat) : nat :=
match n with
| O => O
| S n' => plus m (mult n' m)
end.
Definition one : nat := S O.
Definition two : nat := S(S O).
Fixpoint minus (n m : nat) : nat :=
match n, m with
| O, _ => O
| S _, O => n
| S n', S m' => minus n' m'
end.
Fixpoint fib (n : nat) : nat :=
match n with
| O => O
| one
| _ => plus (fib (minus n one)) (fib (minus n two))
end.
When I tell CoqIDE to go forward with the fib function, it reports "Error: This clause is redundant", and underlines the last case in fib:
What am I doing wrong?
Andrew Pennebaker
- [Coq-Club] SF, Fibonacci, and "Error: This clause is redundant.", Andrew Pennebaker
- Re: [Coq-Club] SF, Fibonacci, and "Error: This clause is redundant.", Edward Z. Yang
Vilhelm Sjöberg
- Re: [Coq-Club] SF, Fibonacci, and "Error: This clause is redundant.", Andrew Pennebaker
- Message not available
Andrew Pennebaker
Adam Chlipala
Andrew Pennebaker
Andrew Pennebaker
Adam Chlipala
Andrew Pennebaker
