coq-club - Re: [Coq-Club] SF, Fibonacci, and "Error: This clause is redundant."
chronological Thread
  • To: Andrew Pennebaker <andrew.pennebaker AT gmail.com>
  • Cc: Coq <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] SF, Fibonacci, and "Error: This clause is redundant."
  • Date: Thu, 03 Nov 2011 17:08:53 -0400
Andrew Pennebaker wrote:
I rewrote fib as:
Fixpoint fib (n : nat) : nat :=
match n with
| O => O
| S O => one
| _ => plus (fib (minus n one)) (fib (minus n two))
end.
Now the error is
Error:
Recursive definition of fib is ill-formed.
Your question prompted me to consider whether I'd made a crucial point clear enough early in CPDT. What do you think of the explanation in the middle paragraph of page 19 in the latest PDF?
   http://adam.chlipala.net/cpdt/cpdt.pdf
On a more meta level, I think a good fraction of the coq-club participants will get annoyed if you keep using the list to ask this level of basic question. I personally have some motivation to make sure I'm not leaving information out of CPDT, so let's tentatively say you can e-mail such questions to me, and I'll often just reply "that's in CPDT." ;-) (And this offer only holds if you're reading through CPDT; I can't tell if you've decided to switch to Software Foundations as a substitute.) Others might volunteer similarly.
