coq-club - Re: [Coq-Club] SF, Fibonacci, and "Error: This clause is redundant."
chronological Thread
  • From: Andrew Pennebaker <andrew.pennebaker AT gmail.com>
  • To: Coq <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] SF, Fibonacci, and "Error: This clause is redundant."
  • Date: Fri, 4 Nov 2011 22:24:47 -0400
Vilhelm, that's it! Would the same code work in Haskell or OCaml?
Cheers,
Andrew Pennebaker
www.yellosoft.us
2011/11/3 Vilhelm Sjöberg <vilhelm AT cis.upenn.edu>
On Thu, Nov 03, 2011 at 03:12:32PM -0400, Andrew Pennebaker wrote:
> Definition one : nat := S O.
> Definition two : nat := S(S O).
> Fixpoint fib (n : nat) : nat :=
> match n with
> | O => O
> | one
> | _ => plus (fib (minus n one)) (fib (minus n two))
> end.
> When I tell CoqIDE to go forward with the fib function, it reports "Error:
> This clause is redundant", and underlines the last case in fib:
> What am I doing wrong?
"one" gets interpreted as a variable bound by the match. You need to write out
the term using constructors:
 | (S O) => one
Vilhelm Sjoberg
