- To: David Leduc <david.leduc6 AT googlemail.com>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] The tactic induction fails :-(
- Date: Sat, 05 Nov 2011 09:31:17 -0400
David Leduc wrote:
How can I prove the lemma cnuf below?
Inductive eqfun : forall X Y, (X->Y) -> (X->Y) -> Prop :=
| refl : forall X Y (f:X->Y), eqfun X Y f f
| func : forall X Y Z (f g:X->Y->Z), (forall x, eqfun Y Z (f x) (g x))
-> eqfun X (Y->Z) f g.
Lemma cnuf : forall X Y Z f g, eqfun X (Y->Z) f g -> (forall x, eqfun
Y Z (f x) (g x)).
It's not obvious to me that your lemma is provable, even given the full set of axioms commonly assumed in Coq developments. You must fundamentally do inversion on [eqfun] with a particular function type as a parameter, which seems to call for a proof step going from [(D1 -> R1) = (D2 -> R2)] to [D1 = D2] and [R1 = R2], but I don't think such a rule is provable in CIC, and I don't think any of the common axioms imply the soundness of this step. It may be validated by the usual Boolean model in ZF, so perhaps it would be consistent to assert this as an axiom.
Or perhaps you could tell us more about the larger context of your development, and we could suggest ways to avoid depending on lemma [cnuf].
- [Coq-Club] The tactic induction fails :-(, David Leduc
- Re: [Coq-Club] The tactic induction fails :-(, Adam Chlipala
- RE: [Coq-Club] The tactic induction fails :-(,
Kenneth Roe
Hugo Herbelin
David Leduc
Tom Prince
David Leduc
- Re: [Coq-Club] The tactic induction fails :-(, Thorsten Altenkirch
David Leduc
Tom Prince
David Leduc
Hugo Herbelin
Kenneth Roe
- Message not available
- Re: [Coq-Club] The tactic induction fails :-(, Bruno Barras
