- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] The tactic induction fails :-(
- Date: Mon, 07 Nov 2011 15:41:58 +0100
On 11/05/2011 02:31 PM, Adam Chlipala wrote:
It's not obvious to me that your lemma is provable, even given the full
set of axioms commonly assumed in Coq developments. You must
fundamentally do inversion on [eqfun] with a particular function type as
a parameter, which seems to call for a proof step going from [(D1 -> R1)
= (D2 -> R2)] to [D1 = D2] and [R1 = R2], but I don't think such a rule
is provable in CIC, and I don't think any of the common axioms imply the
soundness of this step. It may be validated by the usual Boolean model
in ZF, so perhaps it would be consistent to assert this as an axiom.
In fact, the intuitive set-theoretical model disproves it: when D1 = D2 = empty, then D1->R1 = D2->R2 holds for all R1 and R2. Dually, when R1=R2=empty, we cannot deduce D1=D2.
Even when both sets are non-empty, we're not out of trouble: there is a set-theoretical model of Coq which disproves (D1->R1=D2->R2) -> D1=D2 in that case. It uses Aczel's encoding of functions (*), in which D1->{empty} = D2->{empty} (= {empty}) holds for all D1 and D2. (Remember: {empty}=True, and (D1->True) <-> True.)
However, David's problem can be solved without such principle, but just assuming functional extensionality (as Hugo just showed), which is supported by the IZF model.
In Coq, it is most of the time awkward to put arbitrary types as index (when other indexes are constrained by them). You'd better write a "code" for your types and use it as index. David seems to consider only a subset of simple types, so a list of types would do (with the obvious decoding function). You could then make a definition of [eqfun] (by induction on the list) which entails [cnuf] definitionally (no axiom needed).
Bruno.
Peter Aczel's encoding for a (meta-)function f with domain D is
{ (x,y) | x in D and y in f(x) }. Compare this to the standard encoding:
{ (x,y) | x in D and y = f(x) }.
Bruno Barras Typical team - INRIA Saclay
LIX - Ecole Polytechnique 91128 Palaiseau Cedex - France
Tel: +33 1 69 33 40 57 Fax: +33 1 69 33 30 14
- [Coq-Club] The tactic induction fails :-(, David Leduc
- Re: [Coq-Club] The tactic induction fails :-(,
Adam Chlipala
- RE: [Coq-Club] The tactic induction fails :-(,
Kenneth Roe
Hugo Herbelin
David Leduc
Tom Prince
David Leduc
- Re: [Coq-Club] The tactic induction fails :-(, Thorsten Altenkirch
David Leduc
Tom Prince
David Leduc
Hugo Herbelin
Kenneth Roe
- Message not available
- Re: [Coq-Club] The tactic induction fails :-(, Bruno Barras
Adam Chlipala
