- To: David Leduc <david.leduc6 AT googlemail.com>, Coq-Club <coq-club AT inria.fr>, Kenneth Roe <kendroe AT hotmail.com>, Adam Chlipala <adamc AT csail.mit.edu>
- Subject: Re: [Coq-Club] The tactic induction fails :-(
- Date: Sun, 06 Nov 2011 10:45:08 -0500
On Sun, 6 Nov 2011 05:12:33 +0000, David Leduc
wrote:
> Thank you for your replies.
> My main motivation for this question is to define equality on
> functions between presets (i.e., a set without equality. See
> http://nlab.mathforge.org/nlab/show/preset.)
> So the idea of eqfun was to define an equality relation on function
> types without relying on an equality on non-functional types. But
> functional extensionality relies on the equality on the domain of the
> function.
eq is leibniz equality, which is, essentially syntactic equality. I
think it is reasonable to treat 'Type's with Leibniz equality as
presets. In particular, one doesn't have quotients or subobjects of
(non-Sort) types. One can then impose equivalence relations to get
setoids, which behave essentially likes sets, with subobjects and
quotients.
Tom
- [Coq-Club] The tactic induction fails :-(, David Leduc
- Re: [Coq-Club] The tactic induction fails :-(,
Adam Chlipala
- RE: [Coq-Club] The tactic induction fails :-(,
Kenneth Roe
Hugo Herbelin
David Leduc
- Re: [Coq-Club] The tactic induction fails :-(, Tom Prince
David Leduc
- Re: [Coq-Club] The tactic induction fails :-(, Thorsten Altenkirch
David Leduc
David Leduc
Hugo Herbelin
Kenneth Roe
- Message not available
- Re: [Coq-Club] The tactic induction fails :-(, Bruno Barras
Adam Chlipala
